CAI installed now has a late trottle response?
Old Nov 21, 2010 | 01:58 AM
kobebrown7's Avatar
kobebrown7
Default CAI installed now has a late trottle response?
I have a 03 2500 hemi and installed the k&n intake on today and it sounds good but when coasting I can now tap the gas and it has a late throttle response?? I can tap the pedal quicky and the gauge doesnt move? but it seems like sometimes it does ? whats wrong or is that normal?? thanks guys
Old Nov 21, 2010 | 03:15 AM
RedTruck-VA's Avatar
RedTruck-VA
My guess is that you didn't reboot the computer and calibrate the TPPS. Disconnect the battery for 3 minutes. Some folks touch the two cables together, others turn the ignition key on and off. I usually go have a beer. This is a good chance to clean the terminals. Reconnect the battery and turn the ignition switch to the on position without starting the engine and wait 10 seconds. Turn ignition off and then start the engine, she should be already to learn the new settings. Anytime you make a change it is good to give the truck a fresh boot to start from.
Old Nov 21, 2010 | 04:02 PM
kobebrown7's Avatar
kobebrown7
Ok I just went and did that and I will see if it worked here soon.. Thanks alot man for the help!!
Old Nov 22, 2010 | 02:54 AM
kobebrown7's Avatar
kobebrown7
Well after I did it, it seems to work but not everytime? sometimes i tap the gas and it jumps and takes off but sometimes its slow and still when i hit the trottle fast it takes a second still? i only disconnected the negetive sure I disconnect the positive too? i also think its starting to get louder and a deep sound when I WOT???
Old Nov 22, 2010 | 04:04 AM
RedTruck-VA
Ok, when you replaced the air filter did you remove the IAT sensor? If you did check and make sure it was re-installed correctly and the plug is clean and properly connected. I use dielectric grease on all my electrical connections. Pull everything apart and inspect and reassemble. Maybe reboot again and give it another shot. Take your time and be patient while doing it. Is the TB clean? Good luck...
Old Nov 22, 2010 | 06:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My suggestion would be to take the CAI off and put back on the factory setup and see what you get. Ive never heard or a CAI giving a hesitation. I dont like pulling my battery cables to reset the PCM because I loose all my head unit info and settings. I pull my PCM fuse to to each their own.
Besides, it might have something to do with your other thread here.
https://dodgeforum.com/forum/3rd-gen...s-03-hemi.html
