Cam Question.
Old Nov 23, 2010 | 09:34 AM
reddakota34's Avatar
reddakota34
Okay thanks guys ill let you no!
Old Nov 23, 2010 | 11:39 AM
reddakota34
Does anyone have any vids of there 03 cammed hemi? Or of one?
Old Nov 23, 2010 | 01:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Go back to post #7 and PM those guys or look through their threads
Old Nov 23, 2010 | 05:52 PM
truckin151's Avatar
truckin151
Originally Posted by weedahoe
I think because so many guys over the years have been told and repeated to other what they were told about 03's not being able to be tuned. Although they are restricted on raising or lowering idle, I think everything else can be done. With the cams I tried I never had to raise idle anyway so I never understood why someone else like an 03 be able to run them.
What's the normal idle? Isn't it around 650rpm? My truck/cam combo won't idle below 750-800rpm or it stalls out even with the tune, Silverbullets truck with the sidewinder would not idle at the stock rpm so to get it to run he had to bump up the idle by about 200rpm give or take. The more agressive the cam the more likely the idle has to be bumped up or it'll stall.
Old Nov 23, 2010 | 06:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I think stock idle is 700. I know mine I could get down close to 500 and it would idle. Right now it is about 575 in P but in N and D I run it at 650
Old Nov 23, 2010 | 07:09 PM
truckin151's Avatar
truckin151
Hmmm I could have sworn that stock idle in D was around 650. Need someone who is stock to go out and check
Old Nov 24, 2010 | 02:57 AM
AF_HEMI's Avatar
AF_HEMI
If I recall, the OP wants to run a cam on the Superchips tune. If thats the case, good luck. For torque grinds you've got your choice of the 260 or sidewinder, and both of those will be hit or miss as far as the 03's are concerned running on a canned tune.
yeah im running a KRC 210 on a 110lsa, but I may have gotten lucky. No two 03 motors seem to be the same as far as ease of tuning goes. for your best bet, you may need to end up going custom tuned. Either way, your pcm still might not accept it. hemi's are extremely finicky towards tuning. Hate to be the debby-downer, but I say it like it is. I got lucky. You might not.
Old Nov 24, 2010 | 06:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You might be right. Its been so long since Ive been stock
Old Nov 24, 2010 | 08:10 AM
SLT8's Avatar
SLT8
Stock in D mine was 500rpm without A/C and 600rpm w/ A/C.
Old Nov 24, 2010 | 08:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Kay9, all are your performance mods?
