pistons
When finding pistons you need to know what your target compression ration will be. You need to know what CC the head bowls are, what length rods you have, what the crushed thickness of the head gaskets are and what CC the pistons are (dome, dish or flat) and use all of that to calculate not only compression but PTV (piston to valve) clearance so nothing hits one another.
do i have a 32 tooth or 58 tooth reluctor wheel on my crank. this is what i would like to use http://moesperformance.com/index.php...ducts_id=12678
