truck bugged out ...
Old Dec 9, 2010 | 06:21 PM
Michael0077's Avatar
Michael0077
Originally Posted by dodgeboy1979
the solenoids are a cheap fix, (usually mybe $50 a piece and you just have to drop the pan to change them. while the pan is off change the filter and check the magnet for any large pieces or debris. Clean it all up good and fill with new oil.
i stepped on the gas for the first time yesterday, 3-4 gear my tranny made a horrible metal screeching sound, i havn't punched it in months because it used to do that. could that be some debris buildup?
Old Dec 10, 2010 | 04:05 PM
dodgeboy1979's Avatar
dodgeboy1979
ugh usually tranny sounds are not good. With that being said i would drop the pan and take a look for debris, if you have alot of debris a rebuild may be in order.
Old Dec 10, 2010 | 11:15 PM
mopar6spd's Avatar
mopar6spd
Seems to sound like a verter problem, taking a while to fill with fluid or something.
Old Jan 16, 2011 | 05:54 AM
Michael0077
ahhh i'm back again ... truck did this again twice in the past two days.
both times i've back out of a a spot, put it in drive went about 10 feet and the truck just cut out. no jerkin this time or anythin, all happended after a cold start. anything else you guys can think of?
i've still yet to change my tranny fluid though ... i'm an idiot
Old Jan 16, 2011 | 12:37 PM
dirtydog's Avatar
dirtydog
Moderate User
Yeah, you need to change out your filter that is located on the return side of the trans cooler. The original part # has a suffix of AB at the end and hass been replaced with the same part number and NO AB suffix at the end (Mopar part number)
Anyways, the early filters allowed excessive drain back into the TC, so the new one eliminates the problems you are having.
Shouldn't be but a $15 fix!
