Transmission Flush
Old Apr 24, 2011 | 07:42 PM
bigbillhemi03's Avatar
bigbillhemi03
Buggsy that link doesnt work and I've been looking for a DIY tranny fluid change. Anyone help? 03 hemi.
Old Apr 26, 2011 | 12:24 PM
Buggsy's Avatar
Buggsy
Looks like the guy let his domain expire. It's a shame as it was a good guide. I do have a copy of the webpage. If you PM me your email address, I'll send it to you.
On a related note, if anyone wants to re-host it, also PM me and I'll send you what I have. It's a good write up, and should probably be in the FAQ section here.
Old Apr 26, 2011 | 10:12 PM
therogue19090's Avatar
therogue19090
I change my trans fluid and filter religiously every 60k , this way you can see if there is any junk in the pan like metal shavings and clutch debris. I have 160 k on mine now and knock wood its still pulling good. Every time I start to get a little shift issue that has always fixed it and it was always around the time it was due for an oil change. I may look into having the converter drilled for a plug , in the old days you could do that not sure if these converters have a designated spot for a drain plug.
Old Apr 27, 2011 | 09:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats a great idea. Post a thread with all the info and pics if you can or do it in a PDF and LMK so i can move it to the FAQs.
