need help Tracing white wire from alternator?
Old Dec 7, 2010 | 07:08 PM
jwebb's Avatar
jwebb
Default need help Tracing white wire from alternator?
I am trying to trace the white wire that comes off the alternator connector. Found out it must be shot some where because its not charging my battery. On the wiring diagram its the wire that comes of the generator (k125 18 WT/DB) and goes to Leak Detection Pump in between there it splices of to end at the transmission relay. Thats all I know and I have no idea what any of this means so if anyone could help me out. tryed rigging a wire and fuse from the alternator connector (white wire) to the fuse box but still blew fuse and battery is draining. Alternator is charging but not my battery.
Old Dec 7, 2010 | 07:21 PM
brettj2408's Avatar
brettj2408
i will need to know what year, make, model, engine
have you gotten the alternator tested?
Old Dec 7, 2010 | 07:24 PM
jwebb's Avatar
jwebb
Its a 2002 dodge Ram 1500 quad 5.9. Yeah I replaced the alternator thinking it was that then the battery and PCM the regulator was bad in the PCM. My Mechenic traced it to this wire. Thanks
Old Dec 7, 2010 | 07:38 PM
brettj2408's Avatar
brettj2408
all thats labeled on my chart is a black and grey 4 gauge wire going to the generator. and a dark green and a dark blue wire for the connector.
there are no white wires dealing with the generator
Old Dec 7, 2010 | 07:43 PM
jwebb's Avatar
jwebb
I have the green wire but no blue wire. I have a unleaded truck looks like yours is a diesl would the wiring be diffrent?
The green and white wire connector is at the top of my generator.
Old Dec 7, 2010 | 08:33 PM
jwebb's Avatar
jwebb
Default my Diagram
This is a copy of the wiring diagram I am looking at.
Attached Thumbnails need help Tracing white wire from alternator?-_dsc0003-1.jpg
Old Dec 8, 2010 | 09:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
For those maybe wanting a bigger picture. You already know what the wire is and where it goes. You know the Alt is working but not charging the battery. The PCM controls the voltage regulator and does this with the help of a few other sensors like the battery temp sensor (assuming you have one). So you may be looking at bigger electrical issue such as the PCM.
Old Dec 8, 2010 | 04:49 PM
jwebb's Avatar
jwebb
I replaced the PCM, I guess I ll have the new one checked to be sure. Thanks
Old Dec 8, 2010 | 06:04 PM
jwebb's Avatar
jwebb
Default PCM/Windings
Found out that its The new/Referbished PCM the computer is not charging the windings in the alternator.
Old Dec 9, 2010 | 08:38 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I suspected the PCM as i said earlier but how did you determine it was the PCM?
