4x4 indercator light don't work
Old Dec 9, 2010 | 05:52 PM
marv54's Avatar
marv54
Default 4x4 indercator light don't work
I have a 04 1500, when I put it into 4 wheel drive the indicator light don't come on, in spring it when I last used the 4x4 it worked, today it didnt come on. Any advice would be helpful!
Old Dec 9, 2010 | 08:24 PM
brad m's Avatar
brad m
I also have an 04 with the same problem. What works for me is to pop off the boot around the shifter and spray some electrical cleaner-moisture barrier in there. The only thing i can think of is that dirt falls in there since the shifter is on the floor. Good luck.
Old Dec 9, 2010 | 09:18 PM
marv54's Avatar
marv54
Thanks I will give it a try,
Old Dec 9, 2010 | 11:25 PM
Wanderer's Avatar
Wanderer
I had the identical problem, it was a simple and cheap fix. The part is called position sensor, cost about 32 bucks and took 15 minutes to replace. The sensor goes in the front of the transfer case. Make sure the oil ring is reinstalled.
Old Dec 10, 2010 | 11:56 AM
Denniss66's Avatar
Denniss66
did you have to go to the dealer for your sensor. cause i can't find it any where else mine hasn't worked since i blew up my old transfer case and got a used on put in. don't really need it to know if im in 4wd of not but it is nice to see incase i left it in 4wd and start cruising down the highway.
Old Dec 10, 2010 | 03:35 PM
04HemiGreg's Avatar
04HemiGreg
Is that the geographically correct phonetical spelling of "indicator"? LOL - sorry
Old Dec 10, 2010 | 04:06 PM
dodgeboy1979's Avatar
dodgeboy1979
my problem is the 4x4 light won't shut off but i know its disengaged, you think it may be the same sensor you are talking about?
Old Dec 10, 2010 | 05:25 PM
marv54's Avatar
marv54
Sorry I looked at my post it don't make much sense, The indicator light worked in spring and when I used the 4x4, the other day the light didn't come on. haha the wife was nagging me to hurry up so I didn't get a chance to check my post out. Can I get the sensor anyplace other than the stealership?
Old Dec 10, 2010 | 05:29 PM
marv54's Avatar
marv54
lol I live in the sticks and sometimes I spell that way.
Old Dec 10, 2010 | 07:38 PM
brad m's Avatar
brad m
Try putting it in 4wd drive and pull the shifter back Towards the seat and see if the light comes on. That was my problem m
