Whats wrong?
Old Oct 25, 2012 | 03:57 PM
  #41
MoparPaul's Avatar
MoparPaul
Originally Posted by willdikem66
Sorry i thought you meant that your radiator was clogged. You have got me stumpped now
Lol... from the looks of most of your posts it doesn't take much I guess. Do most of us a favor and try reading the thread and comprehend it before chiming in with your mindless banter. This isn't a chat room.
Old Oct 25, 2012 | 04:27 PM
  #42
willdikem66's Avatar
willdikem66
Thanks i appreciate that. Means alot. After every mistake ive made on here you would have to be the only one who was a true jack a** about it. And have you read all 1,000 of my post? Im not ASE ceritifed Mecahanic but but 80% of what i say is usefull or atleast helpful. And if you want to talk about midless banter.... dont you think you could have not wasted a post to tell someone off?
Thanks again.
Old Oct 25, 2012 | 04:42 PM
  #43
Gone Fishin's Avatar
Gone Fishin
Just a heads up for the chemical cleaning of the engine cooling system. There are 2 types of cleaning agents that are recommended for these (aluminum) engines. One is a degreaser, dewaxer, known as sodium metasylicate, the other is acid based, acetic acid and phosphoric acid, or a blend of the 2
They are generally what you'll find somewhere in the ingredients. If you follow the instructions no damage will come to the various coils, and they are best when used in two separate flushes, but done as one big process
Then fully flush a couple of times with fresh water, and refill with your favorite orange antifreeze and distilled or higher quality water-----RO is best if you can get it, but no DI
Old Oct 28, 2012 | 12:56 PM
  #44
metaldad's Avatar
metaldad
Drilled a couple of holes to the left of the blend doors.
can't see everything, this is not the problem. By the way, blend doors do swing to heat position with the fan on high when the actuator not mounted.
I have:
A) back flushed the heater core twice with a garden hose
B) Used Prestone engine flush
C) Disabled the recirc door and jammed it to recirc.
D) taken the dash apart so many times I could do it blind folded.
E) Found that the expansion tank is cracked along the seam on the neck. Replaced with a new OEM.
G) Checked bleed plug on top of engine at the radiator hose connection.
F) I get heat - from any chosen duct - when 'squeezing' a hose. Any hose. Temporary. My thumbs are kinda sore from the heat of the hoses.
Any suggestions?
I don't believe it's the water pump, the temp gage doesn't go past the 12:00 position, which is the normal position.
I don't believe that the stat is bad. Engine seems to heat up from cold in a reasonable amount of time. (i would have a new one installed, except pepboys gave me the wrong one)
WHAT"S WRONG?????????
Old Oct 30, 2012 | 10:40 PM
  #45
metaldad's Avatar
metaldad
Thumbs have blistered from a coupla days ago.
Dumped the coolant - again.
Pulled the water pump. Nothing wrong with the impeller, replaced the pump anyways. New stat.
Refilled. Had the bleed plug out of the block until coolant came out (and on the floor again).
Truck came up to temp in the usual time. Heater hoses were lukewarm. Discharge air was 70. Once again, by manipulating hoses, (and the book says to squeeze to push air out) I would get hot hoses temporarily, and I could get 100 degrees discharge air, temporarily.
The heater return hose goes into a tee, and continues on back to the block. The branch goes to the expansion tank. I vise gripped all 3 hoses, removed the return heater line from the tee, and released the visegrip to 'purge' the core. (and again got more coolant on the floor)
return all to normal, and got a consistent discharge air temp of 115. (way better, still not high enough).
Short of cutting in a tee and a valve to force purge the core, any one have any suggestions.
I'm not trolling.
I'm beat from work. I'm beat from working on this buggy. I just want to give my son some heat. What am I missing?
Does any one have ANY suggestions?
Old Oct 31, 2012 | 10:36 PM
  #46
metaldad's Avatar
metaldad
Over a quarter million members and not one comment?
