Whats wrong?
Old Oct 13, 2012 | 08:23 AM
  #31
metaldad's Avatar
metaldad
yep. same problem with my '02. cold air on the drivers side. I'm not going to pay someone a 1000. I'm going to have to take it apart myself. And I gotta do it soon, winter's coming.
Thanks for the videos.
Replacement blend door/actuator are only available at the dealer?
Old Oct 13, 2012 | 09:44 AM
  #32
metaldad's Avatar
metaldad
Okie dokey. head still spinning from being upside down.
Was able to see movement of the double linked actuator behind the cupholder. So, it's not the actuator, or the pivot points of the links. Movement roughly 70 degrees Door inside the housing busted?
Old Oct 14, 2012 | 05:49 PM
  #33
metaldad's Avatar
metaldad
What a royal pain in the ***.
Disassembled the dash. found all the actuators. seems that the 1 way above the fan, which modulates between recirc and fresh air, was jammed. Because I'm short on time, swapped actuators.
Rainy day, Ram inside carage, had to hurry to get ram drivable, to get '12 Journey in carage before severe t'storms hit.
Didn't remove the HVAC box, Didn't want to touch fluids/refrigerant. Got a better heat on the drivers side. Going to flush coolant system, mebbe acid wash heating coil, before winter hits.
Thank you for all the info and links, as Chilton's and Haynes really don't go into detail.
Old Oct 15, 2012 | 12:14 PM
  #34
willdikem66's Avatar
willdikem66
Just dont let that stuff sit to long or you wont have any heat anywhere
Old Oct 15, 2012 | 07:51 PM
  #35
metaldad's Avatar
metaldad
There is a mild descaler/cleaner we use on heat exchangers called Rydlyme. Supposedly safe, and that's with refrigeration machines.
http://www.apexengineeringproducts.com/
Old Oct 24, 2012 | 09:33 PM
  #36
metaldad's Avatar
metaldad
Well, office lied to me, no rydlyme in shop. Bought Prestone engine flush. Couldn't drain radiator - blocked, not sure of the drain mechanism, don't want to break the plastic. Loosened up the t'stat housing and drained from there. Back flushed the heater core with a garden hose. Ran the flush thru as per instructions, drain, refill with with water, drain, refill with 50/50. Had heat @ 75 out drivers side, 105 passengers. When done, had 130 drivers side, 145+ passenger side.
Worked for 2 days.
No heat period. heater hoses seem hot. (blocked?)
Drain again- from t'stat. back flush core with garden hose. Got some fine rust particles, not a big clump of goo i expected.
Refill, still no heat. Heater hoses hot.
Guess i'll have to pull the damn dash again and fack with the double door for heat/bypass. the motor does move both arms.
This is a major pain in the ****.
Old Oct 24, 2012 | 09:49 PM
  #37
willdikem66
Worked for 2 days.
This is probably your problem. Alot of dodges have clogged radiators. Mine was in line with 3 others when i got mine. You may try to get that clog to come out some how
Old Oct 24, 2012 | 10:40 PM
  #38
metaldad's Avatar
metaldad
Clog. Heater core isn't blocked. Got full flow with a garden hose.
Water pump? No, can't be. Truck doesn't overheat, temp. needle seems to be in ordinary position when 'hot' (approx. 12:00)
Both blend doors busted? Motor moves both arms, approx. 90ish degrees.
Heater core is higher than the hoses.......... air bound? how do you 'vent' the core? Air block would equal no flow. Would both hoses get hot?
It's either an air block or both doors are busted.
Old Oct 24, 2012 | 10:43 PM
  #39
metaldad's Avatar
metaldad
Has anyone ever used a hole saw to punch a hole on the hvac box to see if the blend dampers move?
Old Oct 25, 2012 | 03:28 PM
  #40
willdikem66
Sorry i thought you meant that your radiator was clogged. You have got me stumpped now
