O2 Sensor @ Passenger Upstream of Cat
Old Dec 12, 2010 | 09:03 PM
Red02's Avatar
Red02
Default O2 Sensor @ Passenger Upstream of Cat
Any pointers getting at the sensor on the passenger side that is upstream of the Cat? I have an offset sensor tool from Harbor Freight and have had no luck getting it loosened up. I've shot it with PB Blaster 3 times but still nothing. Anybody done this particular one? Thanks
Old Dec 12, 2010 | 09:24 PM
03MopaRamman's Avatar
03MopaRamman
Welcome to Dodge Forum
I just replaced mine a few weeks ago and added a Bung as well to help with the Rich A/F code I was gettin with my new Cam.
It should come right Off, But the Vehicle should be completely cool. It is cramped for space in there for a Ratchet and 02 Sensor Socket so I used a 22mm Open end wrench as it does fit in there nicely length wise and it gives you lots of leverage (a 7/8 will strip the Nut). Alternatively you could try a closed end wrench on the 02 sensor socket as they usually come with a six point Top like most Spark Plug Sockets. These sensors come already coated with antiseize for a reason.
If you live in an area that is real salty and Humid you might have to heat it up to take it out. Good Luck.
Old Dec 12, 2010 | 11:40 PM
Red02's Avatar
Red02
Thanks. I got it. Even the Harness was stuck together.
Old Dec 13, 2010 | 11:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I just keep my 3/4 wrench with me and use it when doing my O2s. Mine are in and out enough though that they are not frozen.
Old Dec 14, 2010 | 01:46 AM
03MopaRamman
On the 03 Weed, 3/4 won't fit (too small) hence why I quoted the 22mm. weird eh! But then again I only got one Cat!
Old Dec 14, 2010 | 05:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
That is weird. I though O2s were a standard size.......
Old Dec 17, 2010 | 08:32 PM
04Hemi1500's Avatar
04Hemi1500
ya all the ones i have seen were 7/8
Old Dec 20, 2010 | 01:12 AM
03MopaRamman
Yes 7/8 socket will catch it with the six point, but I was talkin open end wrenching in which i needed a perfect fit, and the Replacement Mopar 02 sensor was made in Japan, hence the 22mm Snap-on wrench vice the 7/8.
As you can see in the 02 sockets they call it 7/8 or 22mm or 7/8//22mm which is weird IMO.
http://buy1.snapon.com/catalog/tools...e=snapon-store
