Old Aug 13, 2015, 06:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
remote starter issues
Old Dec 14, 2010 | 09:40 PM
BUMBLE_BEE's Avatar
BUMBLE_BEE
Talking
Originally Posted by techguy_09
hi, having a weird issue lately, in the morning on cold starts when i use my factory remote starter the truck starts then stops andf continues this behavior until i either hit the remote start again or start the truck with the key. im thinking maybe oil pressure? al though i really need to do a tuneup. any ideas?
info:
2007 dodge ram quad 4x4
5.7 MDS hemi
auto
Mega-Hemi
look up this guy he helped me fix my remote start problem. 10-17-2010, 11:39 PM
Mega-Hemi
Vehicle: 2006 1500 SLT Mega Cab 4x4 5.7/Auto
Quote:
Originally Posted by BUMBLE_BEE
I have a 2004 ram 1500 (5.7 hemi) it has the mopar remote start on it and i worked good for about a year than it went all crazy and now i only cherps three time every time i try to us. Anyone know how to fix this or what i need to do???
Did you get your remote start fixed?? If it is beeping 3x and not starting it is in service mode.
Service mode is used whenever it is necessary to disable the remote start feature, such as during vehicle service. The vehicle will not start by remote if Service mode is activated.
Entering Service mode.
A. Turn ignition on with the key.
B. Press the start button on the remote transmitter 3 times. 2 seconds later, the horn will chirp and the lights will flash 3 times, indicating the system
is in Service mode.
C. While in Service mode, whenever a remote start attempt is made, the horn will chirp and the lights will flash 3 times alerting the user that the
system is in Service mode.
Exiting Service mode.
B. Press the start button on the remote transmitter 3 times. 2 seconds later, the horn will chirp and the lights will flash 1 time, indicating the system
has exited Service mode.
Hope this helps. If not let me know.
__________________
SS Steps / Fiberglass Tonneau / Power Sun Roof / 20" AE 079 w/ 34" NTGs
Dodge Forum Military Club
Dodge Forum Motorcycle Club
Old Dec 15, 2010 | 09:17 AM
techguy_09's Avatar
techguy_09
thx i put it into service mode and took it out ill try it tonight when i leave worl
Old Dec 15, 2010 | 11:03 AM
HouseApe's Avatar
HouseApe
Sounds like its the Sentry Key is shutting it down (or the bypass module is faulty or intermittent.
Vehicle starts then stalls - SKIM/SKREEM Interface not learned.
A. Ensure 2 and 4 way connectors are connected
B. Ensure antenna coil is wrapped tightly around the ignition cylinder SKIM/
SKREEM antenna ring.
C. Re-learn SKIM/SKREEM Interface module (see page 15).
5. SKIM/SKREEM Transponder Interface Programming.
2 programmed Sentry keys are required for this step!
NOTE: Review and understand steps A-J prior to performing.
A. Close hood.
B. Insert one of the two valid Sentry Keys into the ignition switch and turn
the ignition switch to the “on” position.
C. After the ignition has been activated for more than 3 seconds (but no
more than 15 seconds), cycle the ignition switch back to the “off” position.
Remove the key and keep it at least 2 feet away from the ignition switch.
D. Within 15 seconds of removing the first key, insert the second valid
Sentry Key into the ignition switch and turn the ignition switch to the “on”
position.
E. Approximately 10 seconds after the ignition has been activated by the
second Sentry Key, the dash theft-security light will start to flash, and a
single audible chime (not the key-in-cylinder chime) will sound to indicate
that the system has entered “Customer Learn” programming mode.
F. Cycle the ignition switch back to the “off” position. Remove the key and
keep it at least 2 feet away from the ignition switch. Theft-security light
will turn off.
G.Press and release the programming button located on the custom harness.
H. Within 60 seconds, press the start button on the remote start transmitter (2) times.
I. Approximately 10 seconds after completion of Step H, a single audible
chime will sound and the theft-security light will stop flashing and stay on
solid for 3 seconds, and then turn off to indicate that the SKIM/SKREEM
Interface module has been successfully programmed.
J. The system will remote start the engine approximately 15 seconds after
Step H. Press the brake pedal to shut down the remote start system.
Note:
In some vehicles, during the SKIM/SKREEM Interface learn procedure,
the vehicle will start and stall on the first remote start attempt. The
second remote start attempt will be successful. This is a normal
condition of the learn procedure. If the vehicle does not start, refer to
the Troubleshooting guide on page 19.
Once a SKIM/SKREEM Interface Module has been programmed to a
WCM/vehicle, it is permanently assigned to that WCM/vehicle and
cannot be used on any other WCM/vehicle.
Old Dec 15, 2010 | 02:46 PM
techguy_09's Avatar
techguy_09
yeah tried it at lunch and now it doesnt even wanna do it during the day.
Old Dec 15, 2010 | 03:15 PM
BUMBLE_BEE's Avatar
BUMBLE_BEE
Which one did you try?
Old Dec 15, 2010 | 03:33 PM
techguy_09's Avatar
techguy_09
just tried the normal way to start it , did the service mode this morning. as far as the SKIm instruction, not too sure what those mean
Old Dec 15, 2010 | 04:08 PM
techguy_09's Avatar
techguy_09
is the module has gone bad , a after market replacement is pretty cheap might just go with one of those
Old Dec 15, 2010 | 06:50 PM
HouseApe's Avatar
HouseApe
Is your Key Gray or Black ?
Edit: opps I see you have an 07....the stuff I posted was for 02-05
Old Dec 15, 2010 | 07:21 PM
HouseApe's Avatar
HouseApe
This is what you want
http://documents.codesystems.com/701236.pdf
and the install book
http://documents.codesystems.com/701082.pdf
Old Dec 15, 2010 | 07:42 PM
03celicagts's Avatar
03celicagts
My compustar remote start/alarm does this exact same thing on my car. But opposite only when the car is exremely hot (ie between runs on time attack course). I never did figure it out. I think it might have something to do with the altenator voltage output in extreme temps ??? I dunno
This is a thread im very interested in what the senior guys on this forum have for a answer.
