dodge ram 1500 help
Old Dec 15, 2010 | 09:55 PM
casey ray's Avatar
casey ray
Default dodge ram 1500 help
i just bought a used 05 dodge ram 1500 and i was looking at putting a leveling kit on it and i went out and measured from the the bottom wheel to the fender and one side is about a half an inch taller than the other side. how can i fix this?
Old Dec 15, 2010 | 10:05 PM
FlameRed04's Avatar
FlameRed04
An alignment could help even out both sides. I know after I had my leveling kit put on, one of my sides was slightly higher than the other. When I took it to the shop to have an alignment done, the tech was able to get it all leveled out for me.
Old Dec 15, 2010 | 10:10 PM
casey ray's Avatar
casey ray
i dont have a leveling kit on mine though. it looks like someone just tried to crank up the torsion keys and didnt do it right because the torsion keys look somewhat stripped
Old Dec 15, 2010 | 10:55 PM
freestyledude's Avatar
freestyledude
Thats normal for it to be a bit off, when you level it you can account for that with a little more spin on the lower side torsion bolt. Or so said Hammer's DIY
Old Dec 15, 2010 | 11:09 PM
HammerZ71's Avatar
HammerZ71
That's what the torsion key bolts are for, to make adjustments with. Pick a side depending on if you want to go UP or DOWN and adjust it to the other.
TIP, you can adjust down with the tires on the pavement, if you want to adjust up, you need to get the weight of the truck off the tires...
Old Dec 16, 2010 | 07:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
if that doesnt work, maybe body spacers can help
Old Dec 16, 2010 | 10:39 AM
viol8r750's Avatar
viol8r750
Default Air bags in the front of a 07 1500?
has anyone ever used air bags in the front of a 07 1500 for leveling or lifting to compensate for a plow.....is it a dumb idea?
Old Dec 16, 2010 | 10:26 PM
mark70669's Avatar
mark70669
Not a dumb idea at all. I did that with my Jeep. You will likely have to fabricate the brackets.
