Stubborn CV Axle - Help!
Old Dec 17, 2010 | 07:24 PM
uponone's Avatar
uponone
Default Stubborn CV Axle
Hey guys
I noticed that the outer boot on the driver’s side CV axle is ripped and all the grease is spraying out. I looked into a replacement boot, but at $30 plus a special installation tool…I might as well put a new axle in (they cost about $60 at my local parts store). The axle is only a couple years old (I changed it about two years ago). I also changed the passenger side CV axle a few months ago while I had the front end apart to replace my hub/bearing. So I’ve done it before and know the basic process but…
Here’s the problem…I can’t get the axle off the stub shaft! I spent the day pounding at it, prying at it, cursing at it. She won’t budge. There is movement (ie, I can slide the cv axle back and forth on the stub shaft and feel the ring grab, maybe 1/16” movement), but I can’t get it to pop off.
I have heard of using a slide hammer, but how? How would it attached…where would it attach?
What’s my next option if I can’t get it off? Open the diff and take off the whole stub shaft? What’s involved in that?
Any opinions would be greatly appreciated! Thanks!
Edit:just found my original post asking the basics steps the job entails...
https://dodgeforum.com/forum/3rd-gen...-cv-joint.html
Old Dec 17, 2010 | 08:06 PM
HouseApe's Avatar
HouseApe
Just get a bigger hammer...
I use a about a 3' piece of 1" round stock and hit them with my 4 lbs hammer.
Old Dec 18, 2010 | 05:44 PM
uponone's Avatar
uponone
Bigger Hammer...check
Actually, I was using a 3' peice of pipe...but very thin walled. I was crushing the pipe more than anything...I need to get a good solid peice of stock like you said. I'll give that a try when I get a chance, Thanks.
Anyone else...go on...don't be shy... :-)
Old Dec 18, 2010 | 07:37 PM
freestyledude's Avatar
freestyledude
I pried at it with a big open end wrench, as well as two tire irons, basically anything I could find lol. Different things have worked each time I pull a CV shaft
Old Dec 20, 2010 | 01:36 PM
uponone's Avatar
uponone
Ok...I'll make this quick cause I'm my hands are currently covered in grease. Got a nice pry bar and a sledge. Hit her a few times and the stub shaft came out of the differential!!! NOW WHAT!
Still trying to seperate the stub shaft from the cv axle. The stub shaft came out of the diff with the snap ring still on.
What do I have to remove out of the diff to fit a new stub shaft in?
Whats my next step...?
I'll try to explain better later (if its not fixed) But any help would be greatly appreciated! Thanks, Ralph
Old Dec 20, 2010 | 01:46 PM
uponone's Avatar
uponone
https://dodgeforum.com/forum/3rd-gen...ic-inside.html
Just found the above link. Looks like I can pop the stub shaft into the diff without having to remove the cover or any innards (as long as the snap ring is still in tact and not laying in the diff)
Now, How do I separate the stub shaft and CV axle on the bench...
Old Dec 20, 2010 | 10:11 PM
freestyledude
That happened to me as well... unfortunately I had to take apart the CV joint, pry a cap off the bottom, and use a hammer and punch to seperate them. Try to keep the grease off your hands if at all possible, it takes forever to wash off
Old Dec 21, 2010 | 04:54 PM
uponone's Avatar
uponone
Thanks for the help! For future reference...and anyone that searches this topic, heres how it went back together....
All done. The above attached link is correct...if the stub shaft pulls out of the differential, it can be popped back in IF the snap ring came out with it and is in tact.
The difficulty was separating the stub shaft and the CV axle...even on the bench it was extremely tough. I had to take a cutting wheel and cut the female spline off the CV axle. Once the two were separated, I ran out and got a new axle seal and a new outer snap ring (inner and outer snap rings are the same part number at dodge, I ruined the old one cutting the CV axle away). Everything went back together smoothly. Set the new axle seal, popped the stub shaft back in, popped the CV axle on, connected the steering ball joint, connected the upper control arm, hub nut, wheel, done Also changed my front diff fluid while I was under there.
Old Jan 7, 2011 | 04:44 PM
justay87's Avatar
justay87
Default name of the boot
Hey,
I have a boot that is cracked open and throwing grease everywhere as well. I would like to just replace the boot, but I can't seem to find it on the websites for a few different parts stores. What is the name that your parts store calls it?
Old Jan 8, 2011 | 12:17 PM
uponone's Avatar
uponone
They just call it a CV Axle boot replacement kit. Not sure what else it would be called.
