Radiator problems in 03 hemi! Air Bubble?
Old Dec 17, 2010 | 08:35 PM
kobebrown7's Avatar
kobebrown7
Default Radiator problems in 03 hemi! Air Bubble?
I changed the fluid in my radiator the other day and filled it up with new clean fluid but I think I have a air bubble in it now? While driving the temp gauge will be at half way then go to three quarter then it will go back down to half way agian and it does it all the time ?? this cant be good right? if its a air bubble how do i fix that? thanks guys
Old Dec 17, 2010 | 10:51 PM
HammerZ71's Avatar
HammerZ71
The "SEARCH" function can be a powerful ally... LOL...
https://dodgeforum.com/forum/3rd-gen...ystem-diy.html
Old Dec 18, 2010 | 06:22 PM
kobebrown7's Avatar
kobebrown7
well i wasnt sure if the guage going back and forth was caused by a air bubble or something else? if you have the cap off while the truck is running wont it overflow when it gets hot ?
Old Dec 18, 2010 | 07:35 PM
freestyledude's Avatar
freestyledude
it might burb a little fluid. Try that first a few times, if that doesn't work I'd try replacing the thermostat
Old Dec 18, 2010 | 10:53 PM
Veibz's Avatar
Veibz
With engine cool, simply take the cap off and start her up. Let the engine run for a good 30minutes or so with the cap off, this will allow the thermostat to open up and let the coolant flow as needed. With that said, the cooling system will "Burp" itself removing the air from the system.
Just did my cooling system a few weeks ago.
Old Dec 19, 2010 | 04:27 PM
abarmby's Avatar
abarmby
My 03 did that and it was the thermostat also as freestyledude said.
I'd burp it first.........then if that doesn't work, I'd replace the Tstat.
Al
Old Dec 19, 2010 | 04:34 PM
HammerZ71's Avatar
HammerZ71
I almost agree with you Al. I'd burp it first, if that didn't fix it then I'd remove the thermostat and drop it in a pot of hot water, bring the water temp up to then see IF the thermostat needs replacing...
