Reverse slipping out
Old Dec 17, 2010 | 08:39 PM
ralaubach's Avatar
ralaubach
From: If at first you don't succeed... go back and reload!
Default Reverse slipping out
So this has happened to me once and my girlfriend twice now. backing the truck up it slips out of reverse and goes to neutral. now she also noticed today when it happened that the indicator box disappeared around the R, and the indicator box was not around the N either. but it was in neutral. Havent checked the fluid yet, but going out the door right now and it will be the first check. if the fluid is good, does anyone have any idea what may be causing this? Thanks for the replies in advance.
Old Dec 18, 2010 | 10:49 AM
Rich 2500's Avatar
Rich 2500
Sound like the shifter might be slightly out of adjustment and not fully in the reverse detent.
Old Dec 18, 2010 | 01:04 PM
CaliDodgeRam's Avatar
CaliDodgeRam
I was having the same problem man, and then i just started making sure i got it into reverse like hard. After i started really assuring that it was in reverse i stopped having the problems.
Old Dec 18, 2010 | 07:48 PM
freestyledude's Avatar
freestyledude
I had that problem a few times when I first bought my truck, just gotta make sure its firmly in reverse before you let go of the handle I think
