engine shuts off randomly WHILE DRIVING!!!
ok i have an 06 mega cab 1500 installed a body lift about 2 months ago and every once in a while while driving at lower speeds like 10 to 30 mph the truck will turn off i dont even notice it right away usually a second or two later i pull the wheel to turn and i feel how its powerless and the brakes barely work usually im quick enough to shift into neutral and turn it back on and its fine but its still scary
it is winter so i can understand if i turn the truck on and imediatly drain the motors stregth by cranking on the power steering or something but this is like 5 minutes into driving and not always mid turn ive had it shutdown going straight
i thought maybe it was related to turning so maybe the steering pump but like i said its happened going straight
anyway any help or input would be great
also battery is only a few months old and is a very strong yellow top optima no problems there no other signs of power drainage turning is fine beside a small 500 watt amp and hids no other aftermarket mods that would drain the battery idk
help would be greatly apprecitated
Think i got your answer.
IS YOUR CHECK ENGINE LIGHT ON? MINE DID THE SAMETHING HAD AUTOZONE PULL THE CODE SAID ERG VALVE. TRYED TO CLEAN IT BUT DID NOT LAST REPLACED IT AND STOPPED DOING IT & GAS MILLAGE WENT UP A LITTLE. NOT THAT MUCH CLEANING IT NOT WORTH THE TAKING OFF AND PUTTING BACK ON JUST TO SEE IT DID NOT WORK. HERE'S A CLIP FROM AUTOZONE.
You may only compare five products at a time.
retailerIdd874f148debugOnfalsevehicleId2946404view categoryHOME>PARTS>EXTERNAL ENGINE>EGR VALVE
EGR Valve
Showing 1 - 1 of 1 Items
Sort by Price: High Low --- Select a Brand --- Duralast
Duralast/EGR Valve Part Number:
EGR4350
Price:
$39.99
Warranty:
2 YR
Notes:
O.E.M. #53032509AH, 53032509AF
STORE PICK UP
AVAILABLE
SHIP TO HOME
AVAILABLE
- HOME
- REPLACEMENT PARTS
- EXTERNAL ENGINE
- EGR VALVE
EGR Valve
EGR4350
Price:
$39.99
Warranty:
2 YR
Notes:
STORE PICK UP
AVAILABLE
SHIP TO HOME
AVAILABLE
