Pacesetter Long tube headers install help
Old Dec 21, 2010 | 08:50 AM
davidonmars's Avatar
davidonmars
Default Pacesetter Long tube headers install help
Looking for some advise from people who have installed long tubes on a Hemi 4x4 how hard was the install. Did you have to jack up the motor or can you just squeeze the long tubes with everything in place. Thanks
Old Dec 21, 2010 | 09:53 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just drop the old manifolds down and put the headers in place. Its is common to find loose or broken manifold bolts so beware. I replaced all my exhaust bolts with grade 8 bolts from Lowes BTW.
You need (17) 8mm-1.25x25mm bolts
Old Dec 21, 2010 | 09:58 AM
HammerZ71's Avatar
HammerZ71
Probably one of the easiest header installs. once you get the wheel well liner out, everything is right there in front of you...
Old Dec 21, 2010 | 10:17 AM
davidonmars
oh alright thanks its just on my old dakota 5.9 long tube install you need to jack the motor up to get clearance. I didnt end up putting them on because the first 2 studs i loosened snapped and I didnt have the patience for that lol
Old Dec 21, 2010 | 10:44 AM
HammerZ71's Avatar
HammerZ71
Well then you prolly don't want to put these on either. My truck was only about 2 years old and had about 20k miles on it when I installed mine, and I still soaked the hell out of them the day before. I didn't have any break, but just about anybody with a Dodge anything who tried to take the exhaust manifold off a vehicle with any age on it has snapp-o'd a bolt or three...
Old Dec 21, 2010 | 10:54 AM
davidonmars
yea well my truck was 12 years old and 300000 km on it haha and the bolts looked horrendous
Old Dec 21, 2010 | 07:56 PM
rangstng's Avatar
rangstng
not trying to jump on your post but i was thinking about doing this too and was wondering if anyone knows if this will affect the lifetime warranty on my truck
Old Dec 21, 2010 | 09:25 PM
luckydt's Avatar
luckydt
david i have them on mine also. It's common for the one bolt hole on the header to not match up so be ready with a carbide bit to oval it out a little.
Rangstng: if your talking factory warranty you would void it. If your talking after market warranty it's possible it would cover it as i found a company that would cover everything on my truck to include lift and tires, but once they found out it had a salvage title that was a no go.
Old Dec 22, 2010 | 08:48 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed, doing something like this is begging the dealership to find a reason to void the warranrty
Old Dec 22, 2010 | 03:01 PM
HammerZ71's Avatar
HammerZ71
Doing anything past a cat back and a CIA is basically begging a dealer to find a reason to void a warranty, LOL...
