Old 08-05-2015, 09:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
Truck starts but won't stay running
Old 01-29-2012, 08:28 PM
rbrumm's Avatar
rbrumm
rbrumm is offline
Weird how the battery will do that! I've never had a vehicle do that before.
Old 01-29-2012, 08:55 PM
boosted-fc3s's Avatar
boosted-fc3s
boosted-fc3s is offline
First the guys at the shop had seen too. Crazy.
Old 01-29-2012, 09:04 PM
stewie01's Avatar
stewie01
stewie01 is offline
Originally Posted by roofseller
Bought a used 2001 Dodge Ram 1500 Larime. Battery was dead when I bought it. Shady Dealer jumped it, ran it all day yesterday, putting on nearly 200 miles its first day on the road, ran beautiful... came out to goto work today, starts but wont stay unless keep my foot on the gas... help!
VIN: 1B7HC13Z01J504957
Year: 2001
Make: Dodge
Style / Body: Quad Cab 4D
Engine: 5.9L V8 MPI
Country of Assembly: United States
Model: Ram 1500 Laramie SLT / ST
Wow. USA huh? Makes me wanna go check mine.
Old 02-20-2013, 08:29 AM
megank's Avatar
megank
megank is offline
I have a similar problem. Please help. I just bought a used 2004 Dodge Stratus with about 46,000 miles on it. It sat for a year without being driven. (I bought it off of a nursing home, selling it for a dementia patient). They replaced the battery before I bought it. It will start right up, but will not stay started unless I give it gas. It used to die in idle, but, I put a liquid tune up and a fuel injector cleaner in my gas tank and that has helped. However, it will die almost immediately after I start it.
Old 02-20-2013, 08:54 AM
ewing111's Avatar
ewing111
ewing111 is offline
Most of the suggestions already given in this post apply to you. You need fuel air and spark. Also you may want to post this in another forum, not sure there's a huge amount of stratus specific knowledge here, you will likely only get general information.
Old 08-05-2015, 01:06 PM
texspike33's Avatar
texspike33
texspike33 is offline
New Member
I have a 02 dodge ram 1500 4.7 4x4 that will start but when I slow down or stop it will die. I change the tps and the iac and the pcm I have check the fuel pressure it read 46 to 50 the relay clicks on when the cars on don't know what else to try? help and I had my battery checked its good
Old 03-24-2018, 12:38 AM
Wrench.it58's Avatar
Wrench.it58
Wrench.it58 is offline
Default Any luck
​​​​​​i have the exact same problem with my 02 ram 4.7 was hoping to find some help I have changed everything thing it stays on but really really rough and only in park if it is in drive and I let off gas dies instantly please let me know if you come across any thing good luck to you as well
Old 03-26-2022, 06:32 PM
Chrisn's Avatar
Chrisn
Chrisn is offline
96 Ram 1500 5.2 won’t idle, and runs rough. Replaced everything ( O2 sensors, fuel temp sensors etc…) over the past 3 months, from timing chain to the ICV. I have disconnected the battery probably 20 times in the past 3 months to keep from burning the systems up while working on it. It starts, hard, but fast, then I have to feather it BIG time to keep it running. I let off the gas and it dies. ( I do not have the air cleaner on it ). I have tried to reset the computer via battery disconnect, cycling the ignition to the on position for 5 minutes etc….the battery holds a charge fine, but it is old and has been through heck. Any ideas would be helpful as I and my mechanic ( a damn good one ) are out of ideas.
thanks…Chris in Kihei!
Old 03-26-2022, 08:25 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Where in the heck is Kihei???
Are you getting any codes? How many miles on it? Any major work done to it in recent memory? Did the problem occur suddenly, or did it sneak in slowly?
Old 07-18-2022, 03:58 PM
mrmojo67's Avatar
mrmojo67
mrmojo67 is offline
Default 1996 Dodge ram same issue
Originally Posted by spinner01
Thanks guys! It indeed was the battery ... thought I'd start there because it was the easiest. It wasn't dead but I had just unhooked it mount some off-road lights. The battery was getting old so I went ahead and replaced it. I started the truck, kept my foot on the brake and RPM's up. Got out of the driveway and got going about 60 mph and then let it coast. The RPM's dropped and it died but I put it in neutral and started it again while coasting. Took it up to about 60 and did it again. This time the RPM's dropped but not to zero. Ended up coasting at an appropiate RPM and after that it has run just fine!
On another note: Just want to say thanks for all the times (almost 2 yrs now) I have come to this forum for advice and repair info without ever registering and asking a question. This time I was at a complete loss and I registered ... so glad I did! Thanks again all.
Had the same issue as you were have 1996 dodge ram thanks for the information I will buy a battery and try that first
Quick Reply: Truck starts but won't stay running
