Quick question, need answer kinda quick! :)
Old Jan 6, 2011 | 10:01 PM
senselesscreationz's Avatar
senselesscreationz
Default Quick question, need answer kinda quick! :)
it is safe to drive my 2005 dodge ram 1500 4x4 without one front shock? if yes how far can i go. im going to nothern va tomorrow from south jersey and need to know if it is ok to take the truck with it missing one front shock. it has the TB in the front. please help
Old Jan 6, 2011 | 10:02 PM
senselesscreationz
that or if i can use a bolt from the rear shocks to use on the front control arm to hold the front shock on? rather have front then back any ideas would be appriciated. i have the new shock just not the bolt yet
Old Jan 6, 2011 | 10:14 PM
rtmtrrdr's Avatar
rtmtrrdr
Couldn't ya go to the hardware store and buy a bolt?.I'd rather do that then drive that far with one shock off
Old Jan 6, 2011 | 11:18 PM
MikeHTally's Avatar
MikeHTally
The hardware store is an option. An auto parts store would have a better chance of having a proper bolt. I wouldn't drive that far with a missing shock.
Old Jan 6, 2011 | 11:27 PM
freestyledude's Avatar
freestyledude
I'd use a grade 8 nut and bolt. Get it tight as you can get (as in right size for the hole)
Old Jan 6, 2011 | 11:28 PM
senselesscreationz
does anyone know the specs for the bolt so i know what size to get?
Old Jan 7, 2011 | 02:17 AM
nussdawg395's Avatar
nussdawg395
Either measure the hole in the shock or take the bolt out of the other side and if you have some where like a fastenal shop they can get you a match.
Old Jan 7, 2011 | 08:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, i would take the other one and get a match for it also. Grade 8 is the way to go.
