Trouble code p0071
Old Jan 16, 2011 | 10:34 AM
will4557's Avatar
will4557
Default Trouble code p0071
This is the code my friends 2008 dodge ram is getting. It has the v6 and is a 6 speed trans. This is the Ambiant Air Tem code. Does anyone know how to fix or what this even is? Thanks in advance!!
Old Jan 17, 2011 | 10:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Is his a gasser or CTD? Has he check his sensor and made sure it is plugged in and the wires to it are good?
Old Jan 17, 2011 | 04:13 PM
lxman1's Avatar
lxman1
Site Moderator
Does the overhead temp display work? The sensor is on the driver side to the left of the headlight assembly.
Old Jan 17, 2011 | 07:18 PM
will4557's Avatar
will4557
The temp sensor was reading all kinds of crazy temps. It is a gasser. Went to the stealership today and picked up a new AAT sensor and replaced it and all is good now!! All the local part stores wanted $25 to $28 for that little part and he got it at the dealer for like $9. Thanks guys for your input!!
Old Jan 18, 2011 | 10:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Glad you got it working
