yet another problem with gas cap
Old Jan 17, 2011 | 09:15 PM
devoisin's Avatar
devoisin
Default yet another problem with gas cap
my engine light came on and then a message came on the dash saying gas cap. i plugged in a code reader and erased the code, the engine light turned off but the gas cap message is still there. anyone know what to do?
Old Jan 17, 2011 | 09:53 PM
slimvela's Avatar
slimvela
the gas cap appears to have a faulty seal based on what your are stating.
Old Jan 18, 2011 | 04:56 AM
bwdakrt's Avatar
bwdakrt
Reset the PCM by disconnecting the negative battery terminal for 1-2 minutes. That should clear the gas cap message but will probably need to replace the gas cap if it comes back.
Old Jan 18, 2011 | 10:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. Some guys have had codes with the fuel cap and have replaced it only to still have the codes but later find the evap hoses under the truck to be cracked. They are located on the evap canister which is in front of the fuel tank.
Old Jan 18, 2011 | 12:18 PM
zencyl's Avatar
zencyl
I had that exact problem, replaced the hoses and now ill get the dash light with that code about once over 4-6 months but the next time i put gas in the truck it goes away. I know alot of my friends with gas dodges have this error come and go randomly.
Old Jan 18, 2011 | 01:43 PM
Cooljay12's Avatar
Cooljay12
Weed has it correct, as usual! I had the same exact issue with mine, engine light-gas cap. Take a look under the left side of the truck where you fill up, you'll see the evap canister. One thing that helped me was to take a look when I was filling up, I could hear and feel the air being forced out of the crack as the fuel went in. If this is the case, you can Macgyver rig the crack or pick up a new canister for pretty cheap from what I have read. I little "Magic Puty" from the late Billy May did the trick for me-for now.
Old Jan 19, 2011 | 10:19 PM
devoisin's Avatar
devoisin
thanks for the reply everyone. i will check things out when we get rid of the -40 temp.
