Change Oil Light Comes On The Odometer When Started
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Does anyone knows how to reset the change oil display in the odometer.
I checked the manual and there is nothing saying how to reset this? I do my own oil changes. Its a 08 ram 5.7l.
Thanks again,
you turn the ignition to run but don't start, wait for the oil change light to begin to flash, then press and release the gas pedal 3 times, then you start your truck up.
thanks DD i had the same issue, although i had found it in the manual but the instructions were kind of vague. that is to say i was trying it in the wrong position
