My 02 Dodge Ram 360 will not start in the cold...
Old Feb 4, 2011 | 05:13 PM
1320King's Avatar
1320King
Default My 02 Dodge Ram 360 will not start in the cold...
I have a 2002 Dodge Ram QCAB 360 4x4 and I began to have problems with it once got really cold outside. I have tried for a couple of days to get it started with no luck....it will crank and crank but not fire up.
The last couple of days it has been in the singe digits 1 to 5 degrees with -19 degrees windchill.
I tried charging the battery and using a quick start function on my battery charger with no luck...the engine will just crank and crank.
I have heard of possible PCM problems with these trucks.....WHere is the PCM and how do I go about removing it so I can try warming it up and reinstalling it?
Today it is warmer.... 28 degrees
Old Feb 4, 2011 | 05:53 PM
Geezir's Avatar
Geezir
have you been plugging the truck in at all?
Old Feb 4, 2011 | 06:05 PM
1320King's Avatar
1320King
No I have not...I thought a block heater was only a option on Diesel pickups. Mine is just a 1500 series with 360 engine.
If there is a block heater option for the 1500 series then where exactly would the plug in be at?
Old Feb 4, 2011 | 06:38 PM
1320King's Avatar
1320King
I noticed on the passenger side of the engine block there is a two prong outlet coming out of where one of the freeze plugs should be....I know that is probably the engine block heater....but where do I get the plug that fits the adapter so I can plug it into an electrical outlet?
Old Feb 4, 2011 | 06:46 PM
Blacksport's Avatar
Blacksport
If it keeps cranking and not starting, I'm leaning towards a fuel delivery problem.
Old Feb 4, 2011 | 07:04 PM
1320King's Avatar
1320King
I guess the fuel pump or something else could go bad overnight. I tried to get the carb(throttle body) hat removed so I could shoot some starter fluid in there but I could not get it off. I loosed the belt clamp that attaches it but it will still not come off.
Old Feb 4, 2011 | 08:04 PM
rbrumm's Avatar
rbrumm
Throw some gas line antifreeze in to see if maybe you don't have a little water freezing in the fuel lines...but I agree it sounds like a fuel delivery problem.
Old Feb 4, 2011 | 08:54 PM
citori13's Avatar
citori13
I had a similar problem. It ended up being electrical. The main problem was a cracked distributor. Mine would not start only on days it snowed because moisture was getting in, so yours could be something different. Maybe fuel pump?
