Rear suspension help!
Old Feb 14, 2011 | 04:39 PM
A1Cscow's Avatar
A1Cscow
Default Rear suspension help!
So I'm stumped yet again. I have the stock springs and the 2 1/2 dayside leveling kit installed. But I can't figure out how to undo what the previous owner did to lower the trucks rear end. I know they used drop shackles and under slung the leafspring. But how do I Go about fixing it?
I shall attempt to post picture links. Apologies if they don't work. I'm doing this over an iPhone.
http://m1217.photobucket.com/albumvi...rVSe2L4TH8tnnX
2B47xfErn1VJvCN7J1JTB7ad9HSRrWffDwp0iLml4lfQouzBrV Se2L4TH8tnnX
Old Feb 14, 2011 | 04:42 PM
A1Cscow's Avatar
A1Cscow
Old Feb 14, 2011 | 04:43 PM
A1Cscow's Avatar
A1Cscow
Old Feb 15, 2011 | 11:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
He moved the leaf pack UNDER the axle to drop it. It should look like this minus the lift block
Old Feb 15, 2011 | 12:10 PM
A1Cscow's Avatar
A1Cscow
Do I need to drop the axle or can I put it on the lift and jack up the bod, and slip the springs back on top
Old Feb 15, 2011 | 01:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You should be able to support the frame with jack stands and remove the leaf pack completely, slide it backwards to the rear and then back forwards over the axle and bolt it all back in place
