2005 warranty question
Old Feb 15, 2011 | 12:34 PM
Croghanite's Avatar
Croghanite
Default 2005 warranty question
Is the water pump/cooling system covered in the factory drivetrain warranty? 7 year/ 70k miles.
It falls under the drivetrain right?
Old Feb 15, 2011 | 01:47 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im not sure but why not call the dealer and see? Do you have a deductible? Might be cheaper and take less time to replace it yourself.
Old Feb 15, 2011 | 01:50 PM
Croghanite's Avatar
Croghanite
I have the 7 year 70000 mile factory warranty so It should be totally covered no deductible right?
Old Feb 15, 2011 | 01:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IDK. And instead of giving you wrong info, I suggest you call the dealer who actually provides the warranty and ask. Thats the most solid and best info I can give on it. I was under 7/70 when my rear end had small issues and I had to pay $100 deductible.
Old Feb 15, 2011 | 02:00 PM
Croghanite's Avatar
Croghanite
i hadn't figured how much trouble it would be to swap a water pump. Have you donr it before? is it bad?
Old Feb 15, 2011 | 02:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its not hard. Just take off the hoses and belt and unbolt it from the engine timing cover.
Old Feb 15, 2011 | 02:41 PM
Croghanite's Avatar
Croghanite
just found out it is a 100 dollar deductible!!! Shoot depending on how many gallons of HOAT I need to put in it could cost a fortune!
23 bucs a gallon
Old Feb 15, 2011 | 02:47 PM
Croghanite's Avatar
Croghanite
just looked in the manual 4 gallons of HOAT!
Old Feb 16, 2011 | 07:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Go get the pump from Autozone and 2 gallons of Prestone OR pay the $100 and let them have the truck for a few days
Old Feb 16, 2011 | 12:48 PM
Powerubi Wacon's Avatar
Powerubi Wacon
I DO believe that the water pump IS covered by the 7yr./70K mile warranty. The deductible is $100.00. Good luck!
