Transmission Oil Change
Old Feb 15, 2011 | 12:59 PM
scampb's Avatar
scampb
Default Transmission Oil Change
I purchased my 2008 Ram 1500 about a week ago. I am having my mechanic look it over on Friday. Should I have him do a transmission oil change? I don't have any service records but I know the previous owner towed a lot with it. It was a lease so I am assuming the previous owener did not put too much time or money into it. Also, can someone explain the benefits of the transmission oil change? How often should it be done? I will not be towing much with the truck.
Thanks,
scampb
Old Feb 15, 2011 | 01:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When it doubt, change it out.
Why should you change it? The same reason you change your engine oil and other wearable parts, because of moving mechanical parts and friction.
Old Feb 15, 2011 | 02:04 PM
scampb's Avatar
scampb
How often would you recommend it be changed? I didn't get an owners manual with it (who takes that out of their glove box).
Old Feb 15, 2011 | 02:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
every 30k
Old Feb 15, 2011 | 03:30 PM
curtQ's Avatar
curtQ
I change mine yearly but it tows 90% on its running time. Also get the tranny flush job done as they don't have filters anymore.
Old Feb 15, 2011 | 05:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ If you are changing it that often then I hope you added a drain plug in the pan by now....lol
Old Feb 15, 2011 | 08:16 PM
nussdawg395's Avatar
nussdawg395
Wait what? Since when dont trannys have filters?
I'd make sure you change the filter when you change trans fluid.
Old Feb 16, 2011 | 07:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
LOL.....I didnt catch that.
Yeah, the 545rfe has TWO internal and replaceable filters
Old Feb 17, 2011 | 11:07 AM
scampb's Avatar
scampb
Thanks for the info all. Is this something I should be able to tackle myself or is it best left for my mechanic? Shouldn't be too much more difficult than changing oil....me thinks!
Old Feb 17, 2011 | 12:02 PM
Buggsy's Avatar
Buggsy
This guy did a good DIY on the transmission fluid change.
http://www.60ateight.com/DodgeRam/
