coolant
Old Feb 17, 2011 | 06:33 PM
red2710's Avatar
red2710
Default coolant
Today after I got home I thought I needed to burp my cooling system and after getting cap off and letting pressure out slowly coolant was low but not bad and let it run for about an hour idiling the sounded like it was spitting out air out small tube from by pass hose is that what it was doing letting out trapped air any ideas let me no thanks 02 dodge RAM 4.7
Old Feb 17, 2011 | 06:38 PM
red2710's Avatar
red2710
Then fluid rose then over flowed then it would drop then it would rise again back and forth till I decided to shut the motor off
Old Feb 17, 2011 | 07:12 PM
chambers's Avatar
chambers
What made you think you needed to burp it? The oem thermostat on the 4.7 and 3.7 has a bleed hole in it to allow trapped air to exit the system, so you shouldn't need to burp it the old fashioned way.
Old Feb 17, 2011 | 10:53 PM
red2710's Avatar
red2710
Was told to after changing the thermistat
Old Feb 18, 2011 | 07:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You have GOT to use some punctuation
Are you running hot?
Old Feb 18, 2011 | 09:38 AM
red2710's Avatar
red2710
No its not
Old Feb 18, 2011 | 09:42 AM
red2710's Avatar
red2710
I think I may need to put a new radiator on it someone before I had the truck put bars leak in it
Old Feb 18, 2011 | 10:03 PM
newfiebullet's Avatar
newfiebullet
Hey Weed is that what they call a run on sentence? Haha
Old Feb 21, 2011 | 10:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
LOL......trust me, my English Professor in college was like a Drill Sargent
