coolant issue help needed
Old Feb 18, 2011 | 08:49 PM
red2710's Avatar
red2710
Default coolant issue help needed
Today I decided to change my thermistat. And it still keeps pushing fluid out the overflow tube.Not sure what the deal is I'm tired of putting money in this truck does anyone think there may be blockage in the radiator? It's realy not running to hot I just don't like the gauge going past the middle mark.any ideas I could realy use thanks.
Old Feb 18, 2011 | 09:26 PM
shortyR6's Avatar
shortyR6
you can flush it with a hose.
make sure the thermostat is installed correctly.
Old Feb 18, 2011 | 10:26 PM
red2710's Avatar
red2710
It's in correct
Old Feb 19, 2011 | 07:25 PM
HouseApe's Avatar
HouseApe
Head gasket could be leaking and pressurized the Rad.
Old Feb 19, 2011 | 10:27 PM
MikeHTally's Avatar
MikeHTally
There is probably some air in the system. Park it nose up, heater on and let it reach operating temperature with the cap loose. The air should bubble out.
Old Feb 20, 2011 | 06:56 PM
red2710's Avatar
red2710
Mike do u mean with the cap all the way off it just loose
Old Feb 20, 2011 | 11:24 PM
brettj2408's Avatar
brettj2408
i would replace your radiator cap. as long as your thermostat is installed correctly and your jiggle pin on your thermostat is at the 12 o clock position
Old Feb 21, 2011 | 06:14 PM
red2710's Avatar
red2710
Why does the jiggle valve need to be at the 12 oclock position is it because of air
Old Feb 21, 2011 | 06:25 PM
MikeHTally's Avatar
MikeHTally
All the way off is probably best. Yes, a little jiggle at 12 o'clock helps the air escape.
