06 Ram Tranny Problem
Old Apr 19, 2011 | 08:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im sure it will be electronic and the 545rfe stands for "rear wheel, fully electronic". a rebuilt trans does have to go through a "re-learn".
Old Apr 20, 2011 | 12:33 AM
06Ramin's Avatar
06Ramin
Well he had the "re-learn" done and checked for updates...did not make a difference at all.
Could it something in the valve body sticking?
Old Apr 20, 2011 | 10:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IDk bro. I just dont know anything else.
Old Apr 23, 2011 | 03:44 PM
Germanator74's Avatar
Germanator74
Hi there,that is a air leak for sure.Check the two short rubber hoses they do connect your transmission cooler with the cooling lines to your transmission,those connectors are worn out.Replace them with hose clips.I had the same problem.
