Question about grease fittings on 06 Ram 5.7 Hemi
Old Feb 21, 2011 | 08:19 PM
Brandonc24's Avatar
Brandonc24
Default Question about grease fittings on 06 Ram 5.7 Hemi
I am trying to do most of the maintenance on my truck by myself. I notice in the manual it say to lube Drivetrain, suspension, and steering grease fittings every oil change. Where are these located? What do I use to lube these fittings? I'm pretty novice when it comes to being a mechanic so any info is greatly appreciated.
Old Feb 22, 2011 | 09:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Oddly enough, there are no grease fittings. Thats why when guys replace ball joints and tie rods and other gears, they buy serviceable parts WITH grease fittings.
Old Feb 22, 2011 | 10:13 AM
Brandonc24's Avatar
Brandonc24
Default Thank You
Ok, so it is not something I should worry about then. So also when I do replace these parts you recommend I switch to serviceable fittings?
Old Feb 22, 2011 | 01:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Almost everyone does and most people swap over to Moog that already has them. You can buy them on ebay, www.rockauto.com and most local auto parts stores.
Old Feb 22, 2011 | 09:14 PM
Brandonc24's Avatar
Brandonc24
Thanks a ton for your help
