Need Some Help With a Code/Part replace
Old Feb 22, 2011 | 01:07 PM
Calvert's Avatar
Calvert
Default Need Some Help With a Code/Part replace
Ok so when i started my truck this morning the check engine light came on, so i brought it by Auto Zone and the guy told me the code was P0441. He said that it meant the EVAP canister Purge Solenoid was bad and needed to be replaced. However when he printed the code and it listed the the top 4 common problems with this code it lists in order
1) Defective or loose fuel cap-(which i have thrown a code for before)
2) EVAP canister or hose cracked-not connected
3) Purge or Vent Solenoid Defective (This is what he said it was, $49.99)
4) Vacuum Leak at Engine
Now i have a 2003 Dodge Ram 1500 5.7 Hemi 2WD, is there anyway to know for sure if it is the solenoid or do i just need to trust the guy? Also i picked up a haynes book to see how to replace the part myself, it gives great pictures of the part but doesnt really describe where on the vehicle it is located and the difficulty of changing it yourself. Is this something i can do or for the hassle am i better off taking it in and getting it done?
Thanks guys!
Old Feb 22, 2011 | 01:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What i would do first is get under the truck and look at the vacuum canister hoses and make sure none are cracked, collapsed or damaged.
Old Feb 28, 2011 | 05:50 PM
Calvert's Avatar
Calvert
Everything looked fine underneath, took it to the dealership they wanted to hook it up to the smoke machine for $199-guy at autozone wanted 55 bucks to order the part and i bought a Chilton so i could replace it...and then i thought you know what-to hell with it im going to try the gas cap...sure enough thats what it was. Thanks for the help Weed. ordered the new shocks and level kit from fatbobs gararage online today hopefully throwing them on this weekend, pricing 35x12.50x20 tires too.
Old Mar 1, 2011 | 07:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Congrats on finding the issue. It is always good to save some money so you can use it elsewhere
Old Mar 1, 2011 | 02:07 PM
i r grunt's Avatar
i r grunt
Got my from fat bobs as well
