Hemi cutting out under load
Old Feb 24, 2011 | 06:48 PM
arani rey's Avatar
arani rey
Default Hemi cutting out under load
Well I fix one thing then another breaks... isn't that my luck?
So my 2005 Dodge Ram Hemi QC 4x4 is cutting out. It runs fine at idle and driving around in a neighborhood, but once you have to go up a hill or speed up a little on a main road it starts cutting out. It seems like maybe the throttle is fluctuating on its own like the fly by wire system is acting up or something like that. Its not a single cylinder miss, its much choppier than that. Feels just like the driver is letting on and off the pedal really fast. The longer you drive it, the worse it gets. Sometimes it will act totally fine for a minute, then go right back to acting up. Maybe a wire short? But where? No CEL, did the key trick thing and it just said 'done' then '--------' then back to '97750' (my mileage).
Does anyone have any ideas on what to do with this? Thanks in advance...
EDIT: Wanted to add in that while its cutting theres a whisshy noise under the hood everytime the rpms drop.. Like a turbo letting off.
Old Feb 24, 2011 | 07:35 PM
MoparMan1991's Avatar
MoparMan1991
Could be a fuel delivery problem? I suppose a turbo kind of noise could indicate a problem with the throttle body (like trying to pull air through a partially closed or fully closed throttle body) Im not exactly sure how those newer engines work, but maybe a Throttle Position Sensor?
Old Feb 24, 2011 | 10:53 PM
vinnierap's Avatar
vinnierap
TPS sensor maybe, or even your injectors could be clogged.
Old Feb 24, 2011 | 11:28 PM
arani rey's Avatar
arani rey
I don't think its fuel related since its so sporadic. Sometimes you can do a WOT run to 60 with no issues and others you wonder if it will make it up the hill at all when its just shaking and cutting out. If it was anything else I'd change the plug wires just to start, but I think the coils are good. I wish it would throw me a code
Old Feb 25, 2011 | 03:40 AM
hemiAK's Avatar
hemiAK
Im not all that mechanically inclined but that sounds exactly like what my sisters chevy was doing when her fuel pump when out. she could drive in town all day long and be fine but as soon as she put it under load going up a hill it would cut out and almost completely die.
Old Feb 25, 2011 | 12:43 PM
arani rey's Avatar
arani rey
I'm going to pull the throttle body and clean it then if it persists maybe have a dealer do diagnostics.. Am I doing the key trick wrong? or is there just no code?
Old Feb 25, 2011 | 04:49 PM
arani rey's Avatar
arani rey
So I did a medium amount of cleaning on the TB, followed the TSB, but I've heard some things about not shooting break cleaner into the TB so theres still a little bit of grunge. That seemed to make it alot better. I ran perfectly until it got fully warm then it stumbled a little under full throttle. Still can't figure out whats going on. I've been in tuners before and this is just like what they call 'fuel cut' or the computer cutting off the gas to protect the motor from something, but what? Still no CEL.
Old Feb 26, 2011 | 09:35 AM
digger20's Avatar
digger20
I had a chrysler act this way and it threw a code for the cam positioning sensor. I replaced it and all was good.
Old Feb 26, 2011 | 03:16 PM
MikeHTally's Avatar
MikeHTally
How many miles on the plugs?
Old Mar 21, 2011 | 01:05 AM
arani rey's Avatar
arani rey
Less than 2000
