07 ram Strange Electrical Problem
Old Feb 24, 2011 | 08:01 PM
crash2510's Avatar
crash2510
Default 07 ram Strange Electrical Problem
I have already asked on other forums but here it is again.
I have an 07 Ram Hemi 4 x 4 1500 that has an unusual problem. Currently it the cruise control works randomly. This however is only a minor problem, the major problem is that when the cruise control is not working the 4x4 will not work. You can always hear the electric solenoid on the transfer case shift, but when the cruise control doesn't work the solenoid on the front axel does not shift. When one works they both works. I have checked for engine codes and none are showing. I have also checked most of the connectors on the truck for corrosion. Any help would be appreciated. Right now I am thinking it might be the computer.
Thanks in advance.
Old Jan 30, 2012 | 03:45 PM
WardenNY's Avatar
WardenNY
Having the same problem myself
Old Jan 30, 2012 | 03:46 PM
WardenNY's Avatar
WardenNY
did you fix it?
Old Jan 30, 2012 | 04:13 PM
freestyledude's Avatar
freestyledude
On the 03's its a corrosion issue in the fusebox. I doused my fusebox in electrical cleaner and it made an improvement. Might be worth a shot?
Old Jan 30, 2012 | 04:39 PM
WardenNY's Avatar
WardenNY
ill give it a shot, thanks
