2.5 leveling kit
Old Mar 3, 2011 | 12:31 PM
ramMan9967's Avatar
ramMan9967
rough country.. i talked to them a few times.. they clame the shocks are too long? i think its just a cover up that they screwed up with this kit
Old Mar 3, 2011 | 01:28 PM
drewactual's Avatar
drewactual
are you sure your tcase isn't engaged in 4wd? are your brakes grabbing for some reason?
having the truck unweighted is going to extend your front suspension more dramatically than at any other time.. if your shocks are crazy long (and topping out with the truck unweighted in the front), I could see them allowing the suspension to move the wheel to a point the angle becomes impossible to overcome, and locking the wheels- but man, we're talking 50 degrees+ on those cv's..
at what angle do you think the cv's are from the hub to the axle?
Old Mar 3, 2011 | 02:48 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by drewactual
since it's in the air still, you could always twirl the torsion adjusters, lowering the ride height- and see when it starts to spin..
He doesn't have that option because he doesn't have torsion bars. Torsion bars/keys are a '02-'05 1500 4x4 thing. He has coil-overs...
Old Mar 3, 2011 | 03:10 PM
weenchops's Avatar
weenchops
hey bud
i had the smae problem on my 07 the rough country kits are junk.... it has to do with the angle of the top of the strut to the top of the shock mount. When you put that spacer in there its causing that bind in the cv's
i recomend going with the rize leveling kit its a 3" i think.. i have one on my truck and love it... i got it from topguncustomz like a year ago
Old Mar 3, 2011 | 03:27 PM
drewactual's Avatar
drewactual
DOH!!! I missed that 'lil fact. Whoops.
Old Mar 3, 2011 | 03:36 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by weenchops
hey bud
3" of level puts those CVs at a pretty big angle. Keep an eye on the boot, they like to tear when they are stretched like that and let all kinds of stuff in that will cause the CV to fail. Give them a good visual inspection every time you change the oil...
Old Mar 4, 2011 | 05:35 AM
ramMan9967's Avatar
ramMan9967
Ill post a pic of the cv joint angle. .its at 48 degrees without any weight on it
Old Mar 4, 2011 | 06:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well what if you lower the truck to the ground and cause the CV angle to lessen?
Old Mar 4, 2011 | 07:58 AM
ramMan9967's Avatar
ramMan9967
Yes it will but I dont trust to drive it like that..if I hit a big bump and the wheel extends too much ill blow the cv joints
Old Mar 4, 2011 | 05:29 PM
ramMan9967's Avatar
ramMan9967
So I ripped the puck out and the cv joint spins just fine. .time to call up rough country and give them an ear full
