fan clutch
Old 03-04-2011 | 08:35 PM
MoparMan1991's Avatar
MoparMan1991
Wow so I just read an entire thread about how to install an electric fan. It looks like a lot of work.
  #22
Old 03-05-2011 | 12:32 AM
chefred112's Avatar
chefred112
naw it isn't...it took me about an hour an a half to do mine..and that's taking my time..
  #23
Old 03-05-2011 | 12:36 AM
MoparMan1991
After reading the entire thread I am definitely intimidated. With my D being my daily driver I need to know exactly what I need and that I won't have any problems.
  #24
Old 03-05-2011 | 12:56 AM
chefred112's Avatar
chefred112
..you need an efan, you need a fan controller...next question..
  #25
Old 03-05-2011 | 01:06 AM
chefred112's Avatar
chefred112
I got a taurus fan (they fit perfectly in the fan shroud) and a dc controller (but the cheaper hayden controllers will work just fine...), the taurus fan is a 2 speed fan, high speed isn't necessary so i used only the low speed. my controller hooked up to battery (and battery ground) and to fan (low speed and ground wire). temp probe from controller to radiator fin...done..
  #26
Old 03-05-2011 | 01:13 AM
chefred112's Avatar
chefred112
I have almost 200k miles on my 05 ram (efan since 30k)...I race it and tow my boat a bunch with it..after the one time my wires fried, i always carry my clutch fan in the bed (haven't had to use it yet)... this is an everday mod and reliable depending on your installation...
  #27
Old 03-05-2011 | 02:20 AM
MoparMan1991
rad probe sounds like drilling into the rad is necessary.
  #28
Old 03-05-2011 | 10:12 AM
MikeHTally's Avatar
MikeHTally
Nah, you just wiggle it through the radiator (near the top hose). No drilling necessary. The e-fan is a very easy install. Just be sure you follow the wiring instructions and use fuses!
  #29
Old 03-05-2011 | 12:52 PM
chefred112's Avatar
chefred112
yup, what Mike says..probe is small enough that you just insert between the fins..
  #30
Old 03-07-2011 | 12:11 PM
OlDirtyJohn's Avatar
OlDirtyJohn
Originally Posted by MoparMan1991
My only concern is that I am unsure if I can get the fan to turn on automatically. How is it done?
wow, so let me get this strait.. you know NOTHING about electric fans, yet you are telling people not to use them under certain circumstances. bravo sir.
Quick Reply: fan clutch
