fan clutch
Old Mar 3, 2011 | 03:54 AM
andrew67's Avatar
andrew67
Default fan clutch
I think my fan clutch is bad how do i check it . I noticed the temp gauge moving around a bit and that i don't hear the fan as much on a cold start up .
Old Mar 3, 2011 | 06:51 AM
MikeHTally's Avatar
MikeHTally
You shouldn't hear the fan on a cold start. There is no need for cooling on a cold engine. When the engine is cold, the fan should free-wheel, or nearly so. When it's hot, the fan should be difficult, if not impossible to move.
You could reach in with a rolled-up newspaper and try to stop the fan when it's cold. Sounds risky, but it should answer your question. I would think on an '08, the clutch would be fine, though.
Old Mar 3, 2011 | 10:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why not go ahead and change it out with an electric fan?
Old Mar 3, 2011 | 12:59 PM
andrew67's Avatar
andrew67
I have checked it hot and cold and it free wheels about the same .
andrew67's Avatar
andrew67
what fans electric fans are people using .
Old Mar 3, 2011 | 01:09 PM
StreetsideStig's Avatar
StreetsideStig
I've heard Flex-A-Lite fans are pretty popular.
Old Mar 3, 2011 | 01:16 PM
frenchbee2306's Avatar
frenchbee2306
yes....there is Flex-A-Lite #180 witch is universal and the #183 more specific to our trucks..
gonna get the #183 soon
Old Mar 3, 2011 | 01:36 PM
andrew67's Avatar
andrew67
With the flex a lite fan do you get rid of the fan clutch .
Old Mar 3, 2011 | 01:48 PM
frenchbee2306
yes , you must remove the factory fan clutch
see the pdf file http://www.flex-a-lite.com/auto/183-99183.pdf
Old Mar 3, 2011 | 03:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
We have lots of threads on efans. There are a few you can use. I have a Taurus fan. Total cost and setup is less than $100
