engine idle
Old Mar 6, 2011 | 11:07 AM
05Troad's Avatar
05Troad
Default engine idle
I am a first timer on this forum, I am having an issue with my o5 4.7 ram, each year when the weather starts to warm up, I get an engine idle surge either at a stop or in park, the surge is constant up and down until I tap the gas slightly then it stops until I drive and when I stop again its back. I have cleaned the throddle body and installed a k&n air filter thinking its not breathing well enough. This problem only happens in the spring summer fall, never in the winter. I have no issues with the truck stalling, excelleration, or sluggish, in fact it tows my boat well. any suggestions?
Old Mar 6, 2011 | 06:22 PM
MikeHTally's Avatar
MikeHTally
Computer reset? MAF sensor issue?
Old Mar 6, 2011 | 08:12 PM
lxman1's Avatar
lxman1
Site Moderator
No MAF on a Ram. IAC valve????
Old Mar 7, 2011 | 01:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You could start by cleaning the TB or changing the EGR valve.
Old Mar 10, 2011 | 08:12 AM
wittfish's Avatar
wittfish
I have the same issue with my 2003 ram. Still trying to figure it out, no codes.
Old Mar 10, 2011 | 09:28 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. Again, check vacuum lines (free), clean the back of the TB ($5), replace the EGR ($40)
