Best Way to lift a 2wd? Here it is....
I looked at that kit....gaaa its soo much though
I would like that bumpstop also but you will still have a fairly harsh ride when it hits? Anyway, some kits say do not get longer shocks and other kits say you need longer shocks. I just dont know anymore. That one has a thread extension but most kits say on 06-08 use stock length
Matt,
When I put the 2" spacers on my 08 I had to buy longer shocks. The stock shocks were about 1" too short. Couldn't even get the nut started on the top when the shock was fully extended. I don't know how a lot of these guys are running stock length shocks.
Hey Daniel Earls i sent you a PM about your truck, did you have sway bar problems when you put the spindles on? Are the spindles the only thing you have done to your truck? Thanks man,, Also, guys what is the best and cheapest place to buy the rear tow/helper air bags.
we definitely need a write-up using the chassistech/aim spindles for sure. Matt99, are you planning on a DIY for all of us?? You seem like the perfect one for it. I hope so. We all would probably be looking forward to that. Let us know and when are you getting the spindles??
I've recieved a couple of inquires if my truck still has its sway bar or not and it does I checked all of the earlier mentioned issues everybody else were having and my is perfectly fine no issues what so ever everything clears and it realigned perfectly.
is there anyway we can get some pictures of the clearance around the sway bar?
