Transmission problem
Old Mar 31, 2011 | 06:33 PM
olzoo83's Avatar
olzoo83
Default Transmission problem
I seem to be having a little issue with my truck, it's a 2006 5.7 with 103k. Sometimes while driving on the highway and the torque converter locks up the truck will shudder, but this doesn't always happen maybe once a day or once a week. So is my torque converter going, or is it something else? Thanks in advance for any help.
Old Mar 31, 2011 | 06:50 PM
lxman1's Avatar
lxman1
Site Moderator
When is the last time the fluid was changed? Wouldn't hurt to flush the fluid and change the filters.
It's not the MDS kicking in and out is it?
Old Mar 31, 2011 | 06:58 PM
olzoo83's Avatar
olzoo83
Changed the transmission fluid about 3k ago hoping it would solve the problem, but it didn't. At what speed is the MDS disabled?
Old Apr 2, 2011 | 02:33 PM
Chris1530's Avatar
Chris1530
did you check your ujoints ?.. had a shudder and thats what it was
Old Apr 3, 2011 | 12:17 AM
lxman1's Avatar
lxman1
Site Moderator
MDS can work at any speed depending on throttle position and engine load. You can try driving in tow/haul mode. It will lock out 5th gear but also disable the MDS.
