High beams on with Fog lights
Old Apr 1, 2011 | 03:47 PM
ccgRAMrod's Avatar
ccgRAMrod
Default High beams on with Fog lights
Who makes the switch that lets you keep your fog lights on when you have your high beams on?
Old Apr 1, 2011 | 04:26 PM
Denniss66's Avatar
Denniss66
there was a link on how to make that possible on here a couple years ago i seen and it had something to do with running a hot wire from the brights fuse to the fog lights or something like that. didn't like the idea so never tried it. run a wire of the brights to a toggle switch then to your fog lights live wire that might work.
Old Apr 1, 2011 | 05:56 PM
Geezir's Avatar
Geezir
Do a search. You just need to tie the two relays together via a short length of wire.
Old Apr 1, 2011 | 06:27 PM
nussdawg395's Avatar
nussdawg395
Yupp check the faqs. There is a writeup in the that shows how to do it with a short piece of wire. Works great too.
Old Apr 1, 2011 | 07:18 PM
Travelin man's Avatar
Travelin man
I think you can pull the fog light relay out and use a small jumper wire and jump from 87 to 30 . I tryed it on my 05 and it worked .
Old Apr 1, 2011 | 09:03 PM
Cthulhu's Avatar
Cthulhu
This may seem like using a shotgun to kill a moth, but a programmer like the Bullydog will allow it as well. That's how I set mine up.
Old Apr 1, 2011 | 09:16 PM
HammerZ71's Avatar
HammerZ71
Only on models that have a TIPM... Pre-'06 Rams are physical (relay controlled)...
Old Apr 1, 2011 | 09:23 PM
Cthulhu's Avatar
Cthulhu
hm... so pre-2006 drivers were still rubbing 2 sticks together for headlights?
Sorry, couldn't resist.
Old Apr 1, 2011 | 10:29 PM
BAXD's Avatar
BAXD
in the fuse box you can run a wire from one fuse to the other
http://img29.imageshack.us/img29/5787/fogs.jpg
im searching for the other pic where it shows which pins it connects to...
Old Apr 1, 2011 | 11:32 PM
HammerZ71's Avatar
HammerZ71
I think I'd rather have 2 sticks than this to try and troubleshoot:
Was a guy on here or maybe another forum not too long ago who couldn't get his brake lights to work, '07 Ram I think it was. Dealer replaced TIPM at a cost of something like $900. Technology is great when it works, but when it doesn't $$$$$$$. I think I'd rather replace a $5 relay, LOL...
