Dodge Build Sheets
Trending Topics
I just went to the dealer with my VIN and asked the service dept to print me out a copy of the build sheet. I literally just did this 2 days ago. I have a question though, for the axle it says Corporate 9.25 LD Rear Axle... now does the LD mean its not a limited slip differential since it doesn't say LSD?
Here is an example of what you will get if you send your request via their contact form (http://www.dodge.com/wccsapp/univers...ull&category=U). You can see if you have the stock LSD it will show up as "DSA Anti-Spin Differential Rear Axle" in addition to "DRBS Corporate 9.25 LD Rear Axle":
Dear Thomas:
Thank you for contacting the Ram Customer Assistance Center regarding
your 2004 Dodge Ram.
In response to your email, we are pleased to provide vehicle build
information as you requested. As per our records, your Ram
(VIN:XXXXXXXXXX) was equipped from the factory with the
following:
Sales Code Description
*M9 Cloth 40/20/40 Prem Bench Seat
-DV Dark Slate Gray
ADA Light Group
AGG Sport Group
AHC Trailer Tow Group
AJB Security Group
ALE Quad Cab Value Group
APAS Monotone Paint
A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ)
BAZS 136 Amp Alternator
BCVP 700 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
CVN Folding Flat Load Floor Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DH5 Elec Shift-on-the-Fly P/Time T/Case
DJMS 205MM HD Front Axle
DMH 3.92 Rear Axle Ratio
EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine
GACS Tinted Glass Windows
GFD Rear Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
I81S Route 81 - UP, Centreville, IL
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
K4DP STRIPE/BADGE/MOLDING/COLOR
LBCS Glove Box Lamp
LBDP Ash Tray Lamp
LCLP Front Dome w/On/Off Switch Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
LSAP Security Alarm
MBPP Body Color Front Bumper
MBQP Body Color Rear Bumper w/Step Pads
MDAS Front License Plate Bracket
MFNP Body Color Grille
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
NAS 50 State Emissions
NBEP U.S. Emissions w/OBD 1
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PDRA Graphite Metallic Clear Coat
QDRS Graphite Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RBQ AM/FM CD 6-Disc Radio
RCKP Infinity Speakers
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTJP P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WGAP 20" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WPG 20X9.0 Aluminum Chrome Clad Wheels
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XJL Front Hood Protection Shield
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email. We appreciate you and your valued business.
Sincerely,
Harry
Customer Service Representative
Dear Thomas:
following:
-DV Dark Slate Gray
ADA Light Group
AGG Sport Group
AJB Security Group
APAS Monotone Paint
EAGC All Gas Engine
JJAS Cigar Lighter
JPBS Power Locks
LBCS Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LNJP Fog Lamps
LPES Cargo Lamp
LSAP Security Alarm
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MXBS Front Air Dam
NHMS Speed Control
WMJP Center Hub
XBSS Pickup Box
Sincerely,
Harry
