2004 Hemi shake n vibrates
Old Apr 17, 2011 | 03:32 PM
macplee's Avatar
macplee
Post 2004 Hemi shake n vibrates
Recently the trucks been shaking and vibrating when accelerating at around 30mph. Vibration is felt throughout the truck but it's not coming from steering wheel. It would also stop vibrating as soon as I let go of the gas paddle. Any advise? U-joint, driveshaft, or something else? No engine light or code. Had tires rebalanced and that didn't help? Any ideas?
Old Apr 17, 2011 | 09:48 PM
Marx's Avatar
Marx
sounds like u-joints
Old Apr 17, 2011 | 10:01 PM
macplee's Avatar
macplee
There are 8 u joints in this truck. I will check them all, but I think it's the ones on the driveshaft. Any thoughts? There is a u joint directly under the driver seat that looks like it won't come out, and the whole unit will need to replace, what is that?
Just changed all 16 spark plugs and wires, and it didn't help. At least the old plugs were looking bad. That took 4+ hours.
Old Apr 18, 2011 | 12:00 PM
freeflycpi's Avatar
freeflycpi
I recently had the same thing....whole front end would shimmy and hum over 40mph....turned out to be wheel bearing. I also didn't feel anything in the steering wheel.
Old Apr 19, 2011 | 12:24 PM
macplee's Avatar
macplee
It's amazing the range of answers/suggestions I have gotten from different shops. The best and most firm answer came from the dealer parts supervisor. Without a doubt he say rear U-joint is going. When gas is applied, it pulls the truck slightly shifting the angle of the driveshaft of rear u-joint. That explains why it smooths out the second gas is released.
He has a 2005 Ram, and he spoke with confidence. I went and purchased both u-joints and plan on doing the job sometime next week. $25 each with grease fitting from Napa Auto.
Sounds good to anyone else???
Old Sep 2, 2011 | 06:04 PM
IndyRamMan's Avatar
IndyRamMan
Any resolution on your problem? Sounds to be what I am experiencing as well.
Old Sep 2, 2011 | 09:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
had a guy on here last week that didnt get vibes until after her replaced the half shaft so keep that in mind even with new parts
Old Feb 13, 2012 | 07:20 PM
Tccards500's Avatar
Tccards500
So what did you find out afte replacing the U-joints, mine is doing the exact same thing, only occurs under acceleration and goes away if i take off the accelerator, or set the cruise...it shakes ***** to the walls or just subtle acceleration
Old Feb 13, 2012 | 07:39 PM
ringo's Avatar
ringo
New Member
I had my rear driveshaft u-joint fail, with the same symptoms you are experiencing. I tried pressing it out without success and ended up cutting it out with a torch. Make sure you mark the position of the drive shaft to rear differential to maintain balance. Buy greasables, I see you have done that. Good luck!
Old Feb 14, 2012 | 09:35 PM
macplee's Avatar
macplee
Sorry for MIA. I did the job myself with the Tiger Tool. I took a bunch of photos and posted it on YouTube as well. This site won't let me post a URL so search "replacing rear axle u joint, dodge ram 2500" on YouTube my user name there is "macplee". A the end of the video there's a link to a web site where I supplied detail instructions step by step. I hope it will help some people.
Good luck.
