Evap leak. Need help.
Old Apr 17, 2011 | 09:23 PM
That1guy's Avatar
That1guy
Default Evap leak. Need help.
My truck keeps throwing a p0442 and once a p0455 code. Both are EVAP leak codes. I've done cleared the codes 3 times. It seems to come on only one start up and moving really slowly. My gas cap is original and i've checked it several times and its not loose. I dont smell fuel. What do I need to check to fix this? Thanks.
Old Apr 17, 2011 | 10:32 PM
lxman1's Avatar
lxman1
Site Moderator
Check the FAQ section. Sounds like a bad hose on the evap canister over the gas tank.
Old Apr 17, 2011 | 10:50 PM
HammerZ71's Avatar
HammerZ71
I've got an evap system map in the FAQ section, trace it out. Odds are you have a cracked hose or a failed clamp. Cheesiest clamps I've ever seen are the ones Chrysler uses...
Old Apr 18, 2011 | 10:48 AM
That1guy's Avatar
That1guy
So is it pretty simple you think?
Old Apr 18, 2011 | 10:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its always simple
Old Apr 19, 2011 | 02:28 PM
That1guy's Avatar
That1guy
I looked through the FAQ and didnt see it. Do you have a link?
Old Apr 19, 2011 | 02:46 PM
HammerZ71's Avatar
HammerZ71
https://dodgeforum.com/forum/3rd-gen...m-diagram.html
