traction bars?
Old Apr 19, 2011 | 09:43 AM
  #21
truckin151's Avatar
truckin151
Originally Posted by ah21283
yeaa i agree, what size tires do you have? and is your truck dropped?
My truck is actually stock hieght for now, eventually it will be dropped 2/4. Tires I am running now are 305/50/20, the widest tire I can fit on a stock rim without any rubbing issues up front.
Originally Posted by weedahoe
Is that why i cant spin my 325/45/24's.....LOL
Yeah I think yours is more the 24's than the tires lol
Old Apr 19, 2011 | 05:07 PM
  #22
ah21283's Avatar
ah21283
im lookin at 275/55/20. sound like a good idea?
Old Apr 19, 2011 | 08:05 PM
  #23
miketrock's Avatar
miketrock
Do any of you guys have a limited slip or locker in the rear ? Are you spinning both rear tires or just ONE ? Adding a Detriot Locker will give you double the traction. I only have an open axle...no Detroit Locker.....yet.
Old Apr 20, 2011 | 12:56 AM
  #24
truckin151's Avatar
truckin151
A 275/55/20 would be as wide as you have now and a little taller in terms of height and unless they are a lot stickier of a tire, you'll just burn through them. See if you can fit a 305/50/20 or 305/45/20 in there. First number is the width, second is the height and the last is the rim diameter. You want wider not taller.
A locker is not very street friendly specially around turns. I have an LSD with the gears and it spins both tires with ease. Now although they both give more traction, at this point that doesnt play to much of a factor as far as spinning on launches go. What he needs is something that will let him grip the road better to gain more traction. So a wider tire and something to help with axle wrap is needed.
Old Apr 20, 2011 | 10:28 AM
  #25
weedahoe's Avatar
weedahoe
Hall of Fame Member
Old Apr 21, 2011 | 04:20 AM
  #26
jmgak47's Avatar
jmgak47
CalTracs and some General Grabber UHP 305/50/20's should fix your traction issues.
