Overhead console swap??? EVIC ?'s
Old Apr 29, 2011 | 08:43 AM
  #21
Brandon Anderson's Avatar
Brandon Anderson
Maybe if a dealer reflashed it, but good luck finding someone who will. I don't know of any dealer who would even touch such a thing. Looking at my other post, I see where it may have been confusing. There are many part numbers and revisions of the Jeep EVIC, and not all of them work in our truck. I was merely compiling a list to show you what the EVICs look like and what you should expect to pay for one. I see two possibilities at this point. One, the EVIC is incompatible and cannot read the signals on your PCI bus. Two, your PCI bus is simply sending a bad signal, which would have been why your OTIS crapped out on you. I would lean towards number one, but let's make sure first. Plug your OTIS back in and perform the same test on it as you did on the EVIC. If it displays "BUS", you've got a much bigger problem.
Old Apr 29, 2011 | 02:13 PM
  #22
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by ccgRAMrod
Yeah and it showed up with the Not Receiving J1850 message. Someone told me that it's because the part number is wrong. Is there a way a Dodge garage can make it work you think?
J1850 is the PCM Protocol our trucks use to communicate
Old Apr 29, 2011 | 02:22 PM
  #23
Brandon Anderson
Correct. Which means either the EVIC doesn't understand what the computer is trying to say (because it's programmed for a different computer), or (much less likely) the computer is sending garbage info. Maybe a wire is grounding out on its way to the overhead. To rule out wiring and the computer however, it would be best to see what the self-diagnostic of the OTIS tells you.
Old Jun 13, 2011 | 02:05 PM
  #24
ccgRAMrod's Avatar
ccgRAMrod
This EVIC unit is compatible with a '03 Dodge Ram?
http://cgi.ebay.com/ebaymotors/CHRYS...item1c1bd55921
Old Jun 13, 2011 | 09:13 PM
  #25
lxman1's Avatar
lxman1
Site Moderator
According to the listing, it fits 98 to 2000 Volvo's.
Old Jun 13, 2011 | 11:55 PM
  #26
Brandon Anderson
Wow, what a find! That model is extremely rare, and has both instant MPG and the TPMS system. Came in the Grand Cherokee's I believe.
** edited for incorrectness - see HemiLonestar's post below **
Old Jun 14, 2011 | 01:28 AM
  #27
HemiLonestar's Avatar
HemiLonestar
No, it won't.
Old Jun 14, 2011 | 03:32 AM
  #28
Brandon Anderson
Originally Posted by HemiLonestar
No, it won't.
No? I thought this model could be done with splicing on the third gens < '06?
Old Jun 14, 2011 | 02:58 PM
  #29
HemiLonestar
Might depend on if it had a factory OTIS install. I swapped from an OTIS to an EVIC and my '03 BCM was a picky bitch. I tried SEVERAL different numbers from different vehicles (Grand Cherokee, 300, Liberty, Durango), the right P/N for that year Ram was the only one that worked CORRECTLY, meaning my temp readout was correct & all programming options worked correctly. I ran into the same problem when I spliced it in to my wife's Liberty. Some of the functions would work, some wouldn't. Once I got the right P/N, all was well.
