2/4 drop on truck problems
Old Jul 3, 2005 | 01:07 AM
Big_K9's Avatar
Big_K9
Default 2/4 drop on truck problems
Just lowered my 03 Ram with a 2/4 Belltech drop. Im having problems with the bolt that holds the brake lines hitting my exhaust. I just switched my dual magnaflow exhaust for dual flomasters. I don't want to switch it again. I already moved the lines once but the bolt is still hitting the exhaust. I was wondering if anybody else was having a prob. like this. Thanks
Old Jul 5, 2005 | 10:21 PM
BMSMWC1's Avatar
BMSMWC1
Default RE: 2/4 drop on truck problems
What size tires do you have. Thinking about doing mine. I would like to go as low as I can with out bagging. 04' Quad. 2wd. w/ 20's. Sory no help though.
Old Jul 6, 2005 | 12:01 AM
Big_K9's Avatar
Big_K9
I have the factory 20s. I love the way it looks, just having some probs with the exhaust and brake lines. Do you have exhaust?
Old Jul 7, 2005 | 06:06 PM
sig's Avatar
sig
who did the install?
Old Jul 7, 2005 | 09:51 PM
Big_K9's Avatar
Big_K9
a local shop
Old Jul 8, 2005 | 08:12 PM
hemimaster's Avatar
hemimaster
what part of the exhaust, if its just a pipe you could fix that like no other, or take it back to the shop the might suggest something.
Old Jul 8, 2005 | 08:23 PM
osteodoc08's Avatar
osteodoc08
Well, you can:
1. Reroute the exhaust.
or
2. Reroute the brake line with braided SS
Old Jul 8, 2005 | 10:44 PM
Big_K9's Avatar
Big_K9
I moved the brake lines but you can't move them to much b/c there is some kind of sensor on the axle (I could be wrong). I am having the exhaust put a little higher or moved. It is knocking the pipe not the tip. Thanks
