Need some help! LT Headers
#22
#24
Welding anything to the collectors is just asking for trouble later on down the road should you need to remove them.
#26
Yeah I finally took off the heat shields and everything to spray the bolts down with PB Blaster. They really don't look bad, not sure what my friend was talking about, think he was in a rush and was looking at the wrong bolts. Anyway, I've got an appointment to have them replaced tomorrow, after that i'll tackle the headers. I may try to get them on this weekend in the driveway unless I run into issues and need a sawzall or something
#27
#28
They'll still fit, no issues with the headers and the wheel well liners as far as fitment goes. You will probably need a sawzall though for the tab on the transmission. Also be sure to piece you setup together BEFORE you take anything off, pacesetters quality control is not to great, for mine the tabs on the collectors needed ground down and heat shield on the floor board needed needed about a softball size dent pounded into it because the tab on the passenger side was in the wrong spot.
#29
On a side note - weed i notice you are no longer using the wheel well guard things as i can see your headers in your sig pic. Is this because they no longer fit afterwards? Also, if i run without them should i be concerned about snow/mud/water getting up in things without them there?
