Cooling fan issues
Old Apr 29, 2011 | 03:02 PM
Jonnydb's Avatar
Jonnydb
Default Cooling fan issues
Sorry if this has been asked.. Maybe I wasnt wording it right but the internet didnt serve me well.. but the Cooling fan right next to the radiator on the driver side.. never stops running.. It starts up right when the truck is started and I wasnt sure if this was normal or if I should get it checked.. All help is appreciated thanks..
Old Apr 29, 2011 | 03:05 PM
Jonnydb's Avatar
Jonnydb
Its an Electric fan btw.. Not sure if that matters..
Old Apr 29, 2011 | 03:31 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats the AC condenser fan BTW. Even if you have the inside blower fan off, does it still run?
Old Apr 29, 2011 | 08:54 PM
lxman1's Avatar
lxman1
Site Moderator
It will run if you have the snowflake switch turned on for the a/c or if you have the control set to floor/defrost or defrost whether the snowflake switch is pushed or not.
These settings turn on the a/c compressor and this requires the condenser fan to run to keep the high pressure under control.
