tach install ??
Old Apr 29, 2011 | 09:24 PM
cawush33's Avatar
cawush33
Default tach install ??
hey guy's my problem is my tach motor in my cluster just died , so no rpm
but now i want to install a tach , no need the shift light , my truck is auto, and i know the coil over the plug is a problem with some tach model, beside the wire from the plug or injector , is there another wire can i find to plug the tach in ?? like in the cluster ? and do i really need the adapter to connect a ( regular tach ) ???
i got a dodge ram slt 2008 5.7 hemi
is anybody does this before ?
Old Apr 29, 2011 | 11:23 PM
lxman1's Avatar
lxman1
Site Moderator
You might contact someone like MSD. You will need some type of tach adapter since the PCM drives the cluster tach and a signal from a coil.
Old May 2, 2011 | 12:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or you could always use a nice computer based or tuner based tach.
Old May 3, 2011 | 03:00 PM
cawush33's Avatar
cawush33
i read in another forum , i can use a speedhut tach that you don't need an adapter to read the signal ?? you can set the pulse rate and it's programmable ? someone can help on this , and did someone hook up an aftermarket tach on their ram 1500 5.7 hemi ?? because i'm really stuck on info ? there's nothing about how to wire that beast !!!
Old Sep 19, 2024 | 02:42 PM
RAMCHARGER1980's Avatar
RAMCHARGER1980
Default Tach
but now i want to install a tach , no need the shift light , my truck is auto, and i know the coil over the plug is a problem with some tach model, beside the wire from the plug or injector , is there another wire can i find to plug the tach in ?? Like in the cluster ? And do i really need the adapter to connect a ( regular tach ) ???
I got a dodge ram slt 2008 5.7 hemi
i used a dakota digital obd2 and it wired in very easy and aftermarket tach works great
Old Sep 19, 2024 | 03:28 PM
Prismatic's Avatar
Prismatic
This thread is so old it can drive
Old Sep 19, 2024 | 05:38 PM
Alex Medeiros's Avatar
Alex Medeiros
Originally Posted by prismatic
this thread is so old it can drive
