Speedometer broken, abs and park light on
Old May 14, 2011 | 03:02 PM
aromanj92's Avatar
aromanj92
Exclamation Speedometer broken, abs and park light on
so my speedometer is jumping around barely works but if i lay on the gas than it'll start to work or sometimes just jump around. on top of that my abs light and park brake light are always on. i got abs sensor replaced but it didnt do anything. anyone have any help?
also does anyone know an estimate for how much new back vent window is? my brackets that hold it all broke somehow and need of new ones . thanks
Old May 14, 2011 | 08:32 PM
cawush33's Avatar
cawush33
it can be not the abs sensor, but the wiring ! the speed sensor , abs sensor , tach sensor , i think the fuel meter is on the same wire connector , the thing work in a pulse mode , so just one wire can be connected to all of the gauge and sensor so my first try will be the wire from the speedo and abs , try to follow wire to see if you did not see a cut in the wire ?
Old May 15, 2011 | 01:01 PM
aromanj92's Avatar
aromanj92
Default Actions done
i checked the wire and also got the shop to check the wire they said its hot and its all fine but the speedometer and lights just are not responding. so with that could it be the speed sensor or the shop said something about a pcm or something like that.
Old May 15, 2011 | 01:27 PM
atthewmartin114's Avatar
atthewmartin114
check how the speed sensor in the transfer case is installed and make sure its plugged in all the way. that one in the transfer case is the start to the abs system.
Old May 15, 2011 | 07:27 PM
lxman1's Avatar
lxman1
Site Moderator
Not even close to the right forum!!
